    [Plugin] V-Ray Tools
    238 Posts 80 Posters 290.1k Views 80 Watching
      tequilawine
      when i tried this plugin, i can not export pic and sometimes i don't know why i can't get the right rendering ratio
      • tt_suT Offline
        tt_su
        Can you describe in more detail?
        Do you get errors in the Ruby Console (if you keep it open)?
        Do you have screenshots of what you see?
        What are the steps you do when you can not export?
        • I Offline
          itsupport
          Ello,
          Loving this Tool for quick loading V-Ray - really awesome. We can only install this plugin by copying the rpz files (unpacked) to the SketchUp plugin directory.
          It means we have to manually click Windows > Pref > and select the tools for every first time use. Is there a way round this, that the newly copied TT plugin files could also be set to be loaded (but not the actual V-Ray plugin obviously)?
          Many thanks in advance πŸ˜„
            I'm sorry but I don't quite understand the question here.
            Is it an installation issue?
            • I Offline
              itsupport
              Hi Thomthom - thanks for the super speedy reply πŸ˜„
              So we are copying the unpacked files to the plugin folder. This works fine, but on first use they aren't setup as default enabled, so it has to be done manually. Once enabled, everything seems to work great.
              How would we enable the plugin on first SketchUp use using this method (EG, not using sketchup plugin installer) ? If it means enabling all plugins that that would be ok (not ideal) - is there a registry setting or something we could set a GPO up to always enable the plugin ?
              Many thanks ! πŸ˜„
                tacomomo
                @miamiarnold said:
                "Installed your plugin and it somehow messed up the material link when you pick a material from sketchup model it doesn't reflect on the vray material editor, the selection in the vray material editor is always stuck on 1 material, tried uninstalling the ruby by deleting the files and folder in the sketchup root folder then uninstalled sketchup and re installed but i seem to get the same problem am using vray 2.0 and sketchup 2013, seems the problem might have started when i purged materials using vray tools, i have also tried copying the model to a fresh sketchup file but still nothing fruitful, 😞 the project is due and am stuck i get this error when i open the file
                Error Loading File C:\ProgramData/ASGVIS/VfS/Ruby/R2P.rb
                undefined method entityID' for nil:NilClass Error Loading File vfs.rb undefined method entityID' for nil:NilClass
                any help will be appreciated, and thanks in advance. i just need my vray back to the way it was thank you"
                please help him too because we encounter the same problem
                  Didn't notice this until now... :s
                  What does it mean that "material editor is always stuck on 1 material"? I'm really not sure what is being described here. Any screenshots? Sample model?
                  • I Offline
                    itsupport
                    Many thanks ! πŸ˜„
                    Ello, have you any thoughts about this, I hope it's clearer to understand, but pelase let know if I've not made it clear.
                    Kind Regards πŸ˜„
                    • I Offline
                      itsupport
                      No Worries,
                      Got it sorted, we wrote a little program to open your plugin's first, and also to not allow V-Ray plugin to open so that your excellent programs control it by default.
                      Cheers
                      • maeglin1M Offline
                        maeglin1
                        For me this is the best tool ever. Saved me alot of frustration and stress with all the Vray issues. A BIG Thankyou πŸ˜„
                          sanjaygrg
                          Hi everybody,
                          I installed TTLib v2.9.9 and ttvray tools v2.2.1 (sketchup 8, vray for SU 2), I can't find the camera tools in vray camera tool toolbar. My question is whether camera tool is not available in vray for SU ver. 2.
                          • tt_suT Offline
                            tt_su
                            Should be there... what does your toolbar look like?
                              sanjaygrg
                              here is the attachment of the toolbar..
                                sanjaygrg
                                • tt_suT Offline
                                  tt_su
                                  That's the menu, do you have a screenshot of the toolbar?
                                    sanjaygrg
                                    here is the toolbar screenshot..
                                    • tt_suT Offline
                                      tt_su
                                      Toolbars are the icons under the menus. View > Toolbars
                                        dikasita
                                        Sir thomtom
                                        how to load vray toys? i hv install tt lib and vray tool from this thread
                                        but i cant find vray toys
                                        im using SU2013
                                        thanks
                                        • john2J Offline
                                          john2
                                          I'm getting the following error in 2014 SU
                                          Error Loading File vray_toys.rb
                                          Error: #<LoadError: 126: The specified module could not be found. - C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/RubyWinFunc.so>
                                          C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                          C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:22:in getWindowsASGVISFolder' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:42:in getASGVISRubyFolder'
                                          C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:46:in <top (required)>' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                          C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:58:in module:VRay_Loader'
                                          C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:47:in <module:VRay_Toys>' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:45:in <top (required)>'
                                          C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vray_toys.rb:101:in `<top (required)>'
                                            John, that error is V-Ray Tools trying to load V-Ray. But the version of V-Ray you have installed doesn't work with SU2014.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 10 / 12
