    [Plugin] V-Ray Tools
    238 Posts 80 Posters 295.0k Views 80 Watching
    • I Offline
      itsupport
      Ello,
      Loving this Tool for quick loading V-Ray - really awesome. We can only install this plugin by copying the rpz files (unpacked) to the SketchUp plugin directory.
      It means we have to manually click Windows > Pref > and select the tools for every first time use. Is there a way round this, that the newly copied TT plugin files could also be set to be loaded (but not the actual V-Ray plugin obviously)?
      Many thanks in advance πŸ˜„
        I'm sorry but I don't quite understand the question here.
        Is it an installation issue?
        • I Offline
          itsupport
          Hi Thomthom - thanks for the super speedy reply πŸ˜„
          So we are copying the unpacked files to the plugin folder. This works fine, but on first use they aren't setup as default enabled, so it has to be done manually. Once enabled, everything seems to work great.
          How would we enable the plugin on first SketchUp use using this method (EG, not using sketchup plugin installer) ? If it means enabling all plugins that that would be ok (not ideal) - is there a registry setting or something we could set a GPO up to always enable the plugin ?
          Many thanks ! πŸ˜„
            tacomomo
            @miamiarnold said:
            "Installed your plugin and it somehow messed up the material link when you pick a material from sketchup model it doesn't reflect on the vray material editor, the selection in the vray material editor is always stuck on 1 material, tried uninstalling the ruby by deleting the files and folder in the sketchup root folder then uninstalled sketchup and re installed but i seem to get the same problem am using vray 2.0 and sketchup 2013, seems the problem might have started when i purged materials using vray tools, i have also tried copying the model to a fresh sketchup file but still nothing fruitful, 😞 the project is due and am stuck i get this error when i open the file
            Error Loading File C:\ProgramData/ASGVIS/VfS/Ruby/R2P.rb
            undefined method entityID' for nil:NilClass Error Loading File vfs.rb undefined method entityID' for nil:NilClass
            any help will be appreciated, and thanks in advance. i just need my vray back to the way it was thank you"
            please help him too because we encounter the same problem
              Didn't notice this until now... :s
              What does it mean that "material editor is always stuck on 1 material"? I'm really not sure what is being described here. Any screenshots? Sample model?
              • I Offline
                itsupport
                Many thanks ! πŸ˜„
                Ello, have you any thoughts about this, I hope it's clearer to understand, but pelase let know if I've not made it clear.
                Kind Regards πŸ˜„
                • I Offline
                  itsupport
                  No Worries,
                  Got it sorted, we wrote a little program to open your plugin's first, and also to not allow V-Ray plugin to open so that your excellent programs control it by default.
                  Cheers
                  • maeglin1M Offline
                    maeglin1
                    For me this is the best tool ever. Saved me alot of frustration and stress with all the Vray issues. A BIG Thankyou πŸ˜„
                      sanjaygrg
                      Hi everybody,
                      I installed TTLib v2.9.9 and ttvray tools v2.2.1 (sketchup 8, vray for SU 2), I can't find the camera tools in vray camera tool toolbar. My question is whether camera tool is not available in vray for SU ver. 2.
                      • tt_suT Offline
                        tt_su
                        Should be there... what does your toolbar look like?
                          sanjaygrg
                          here is the attachment of the toolbar..
                            sanjaygrg
                            • tt_suT Offline
                              tt_su
                              That's the menu, do you have a screenshot of the toolbar?
                                sanjaygrg
                                here is the toolbar screenshot..
                                • tt_suT Offline
                                  tt_su
                                  Toolbars are the icons under the menus. View > Toolbars
                                    dikasita
                                    Sir thomtom
                                    how to load vray toys? i hv install tt lib and vray tool from this thread
                                    but i cant find vray toys
                                    im using SU2013
                                    thanks
                                    • john2J Offline
                                      john2
                                      I'm getting the following error in 2014 SU
                                      Error Loading File vray_toys.rb
                                      Error: #<LoadError: 126: The specified module could not be found. - C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/RubyWinFunc.so>
                                      C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                      C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:22:in getWindowsASGVISFolder' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:42:in getASGVISRubyFolder'
                                      C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:46:in <top (required)>' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                      C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:58:in module:VRay_Loader'
                                      C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:47:in <module:VRay_Toys>' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:45:in <top (required)>'
                                      C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vray_toys.rb:101:in `<top (required)>'
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                        John, that error is V-Ray Tools trying to load V-Ray. But the version of V-Ray you have installed doesn't work with SU2014.
                                        • john2J Offline
                                          john2
                                          Thanks a lot. Now I've fixed every damn error that was coming. Now I have an error free startup. feeling relieved just like you do after you cleanup your room after weeks.
                                            I know that feeling!
                                            • 11
                                            • 12
                                            • 10 / 12
