    [Plugin] V-Ray Tools
    238 Posts 80 Posters 301.7k Views 80 Watching
    • maeglin1M
      maeglin1
      For me this is the best tool ever. Saved me alot of frustration and stress with all the Vray issues. A BIG Thankyou πŸ˜„
        sanjaygrg
        Hi everybody,
        I installed TTLib v2.9.9 and ttvray tools v2.2.1 (sketchup 8, vray for SU 2), I can't find the camera tools in vray camera tool toolbar. My question is whether camera tool is not available in vray for SU ver. 2.
        • tt_suT
          tt_su
          Should be there... what does your toolbar look like?
            sanjaygrg
            here is the attachment of the toolbar..
              sanjaygrg
              • tt_suT
                tt_su
                That's the menu, do you have a screenshot of the toolbar?
                  sanjaygrg
                  here is the toolbar screenshot..
                  • tt_suT
                    tt_su
                    Toolbars are the icons under the menus. View > Toolbars
                      dikasita
                      Sir thomtom
                      how to load vray toys? i hv install tt lib and vray tool from this thread
                      but i cant find vray toys
                      im using SU2013
                      thanks
                      • john2J
                        john2
                        I'm getting the following error in 2014 SU
                        Error Loading File vray_toys.rb
                        Error: #<LoadError: 126: The specified module could not be found. - C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/RubyWinFunc.so>
                        C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                        C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:22:in getWindowsASGVISFolder' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:42:in getASGVISRubyFolder'
                        C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vfs.rb:46:in <top (required)>' C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                        C:/Program Files (x86)/SketchUpfresh/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:58:in module:VRay_Loader'
                        C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:47:in <module:VRay_Toys>' C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VRayToys/vr_loader.rb:45:in <top (required)>'
                        C:/Users/john2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/vray_toys.rb:101:in `<top (required)>'
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          John, that error is V-Ray Tools trying to load V-Ray. But the version of V-Ray you have installed doesn't work with SU2014.
                          • john2J
                            john2
                            Thanks a lot. Now I've fixed every damn error that was coming. Now I have an error free startup. feeling relieved just like you do after you cleanup your room after weeks.
                              I know that feeling!
                              • john2J
                                john2
                                I'd have given you a hug man if you were in front of me. 😍
                                • N
                                  NikeScor
                                  Very Good, Sir.
                                    ssfat06
                                    @miamiarnold said:
                                    Installed your plugin and it somehow messed up the material link when you pick a material from sketchup model it doesn't reflect on the vray material editor, the selection in the vray material editor is always stuck on 1 material, tried uninstalling the ruby by deleting the files and folder in the sketchup root folder then uninstalled sketchup and re installed but i seem to get the same problem am using vray 2.0 and sketchup 2013, seems the problem might have started when i purged materials using vray tools, i have also tried copying the model to a fresh sketchup file but still nothing fruitful, 😞 the project is due and am stuck i get this error when i open the file
                                    Error Loading File C:\ProgramData/ASGVIS/VfS/Ruby/R2P.rb
                                    undefined method entityID' for nil:NilClass Error Loading File vfs.rb undefined method entityID' for nil:NilClass
                                    any help will be appreciated, and thanks in advance. i just need my vray back to the way it was thank you
                                    I have the same problem.Problem solved? Does any suggestion?
                                    purged model => error message occurred after open the saved file again.
                                    Appreciated.
                                      What version of VfSU are we talking about here?
                                      Got a sample model?
                                        What what was the steps that caused it?
                                          JJOKLONG
                                          Hi TT.
                                          I search this error on GG and this is the topic have same problem with me.
                                          I close Sketchup after render done and when come back,this error happened.
                                          Dont know how to fix this.It's only my artwork but I'm afraid this error will happen later.
                                          My PC is i7 2600,ram 8GB,VGA 550Ti.
                                          Su 2013 and VFSu 2.0
                                          Thanks for your help.
                                          undefined method entityID' for nil:NilClass Error Loading File C:/PROGRA~2/SketchUp/SKETCH~2/Plugins/vfs.rb undefined method entityID' for nil:NilClass
                                          error
                                            @jjoklong said:
                                            Hi TT.
                                            Did you use V-Ray Tools in any way?
                                            • 11
                                            • 12
                                            • 10 / 12
