    [Plugin] V-Ray Tools
    238 Posts 80 Posters 295.0k Views 80 Watching
    • V Offline
      vojo
      ok...so some genius suggested that this VRAY plugin was better than export 2d. So I loaded it (and as with the mess this whole plugin family indicates....newer versions of supporting plugins create errors). Got that fixed....got Vray installed. Now says cant load and asks if installed correctly. Since I get the menus and such...appears to be installed in some state.
      Forget this
      Going to use export 2d from now on!!!!!!!!!!!!!!
        Forget this
        Again, as I mentioned in the other thread - you're not really helping yourself much by not describing exactly what isn't working.
        What version of V-Ray do you have installed?
        But you say you wanted to use it as a replacement for export 2d... do you even have V-Ray installed? In which case you should ignore the Load V-Ray button and just use the Camera Tools button.
          redsteel
          @thomthom said:
          That's a bad bug in SketchUp 2013. The toolbar is there - it's just that it's hidden underneath your existing docked toolbars.
          I knew that I wasn't crazy. Thanks for the answer πŸ˜›
            Yea - you're not crazy. But the bug is. They are working on a fix though.
            • Alan FraserA Offline
              Alan Fraser
              That V2013 bug is more easily overcome by simply unchecking and then rechecking V-Ray Tools in the View > Toolbars dialog. it removes itself from wherever it was hiding and relocates to a floating position in the drawing space.
              3D Figures
                Didn't work for me...
                • pyrolunaP Offline
                  pyroluna
                  Thomas you're a champ.
                  As always.
                  I really like the update to the V-ray tools πŸ˜„
                  Especially the load-on-demand saves me a headache every time I start SketchUp!
                    miamiarnold
                    Installed your plugin and it somehow messed up the material link when you pick a material from sketchup model it doesn't reflect on the vray material editor, the selection in the vray material editor is always stuck on 1 material, tried uninstalling the ruby by deleting the files and folder in the sketchup root folder then uninstalled sketchup and re installed but i seem to get the same problem am using vray 2.0 and sketchup 2013, seems the problem might have started when i purged materials using vray tools, i have also tried copying the model to a fresh sketchup file but still nothing fruitful, 😞 the project is due and am stuck i get this error when i open the file
                    Error Loading File C:\ProgramData/ASGVIS/VfS/Ruby/R2P.rb
                    undefined method entityID' for nil:NilClass Error Loading File vfs.rb undefined method entityID' for nil:NilClass
                    any help will be appreciated, and thanks in advance. i just need my vray back to the way it was thank you
                      tequilawine
                      when i tried this plugin, i can not export pic and sometimes i don't know why i can't get the right rendering ratio
                      • tt_suT Offline
                        tt_su
                        Can you describe in more detail?
                        Do you get errors in the Ruby Console (if you keep it open)?
                        Do you have screenshots of what you see?
                        What are the steps you do when you can not export?
                        • I Offline
                          itsupport
                          Ello,
                          Loving this Tool for quick loading V-Ray - really awesome. We can only install this plugin by copying the rpz files (unpacked) to the SketchUp plugin directory.
                          It means we have to manually click Windows > Pref > and select the tools for every first time use. Is there a way round this, that the newly copied TT plugin files could also be set to be loaded (but not the actual V-Ray plugin obviously)?
                          Many thanks in advance πŸ˜„
                            I'm sorry but I don't quite understand the question here.
                            Is it an installation issue?
                            • I Offline
                              itsupport
                              Hi Thomthom - thanks for the super speedy reply πŸ˜„
                              So we are copying the unpacked files to the plugin folder. This works fine, but on first use they aren't setup as default enabled, so it has to be done manually. Once enabled, everything seems to work great.
                              How would we enable the plugin on first SketchUp use using this method (EG, not using sketchup plugin installer) ? If it means enabling all plugins that that would be ok (not ideal) - is there a registry setting or something we could set a GPO up to always enable the plugin ?
                              Many thanks ! πŸ˜„
                                tacomomo
                                @miamiarnold said:
                                "Installed your plugin and it somehow messed up the material link when you pick a material from sketchup model it doesn't reflect on the vray material editor, the selection in the vray material editor is always stuck on 1 material, tried uninstalling the ruby by deleting the files and folder in the sketchup root folder then uninstalled sketchup and re installed but i seem to get the same problem am using vray 2.0 and sketchup 2013, seems the problem might have started when i purged materials using vray tools, i have also tried copying the model to a fresh sketchup file but still nothing fruitful, 😞 the project is due and am stuck i get this error when i open the file
                                any help will be appreciated, and thanks in advance. i just need my vray back to the way it was thank you"
                                please help him too because we encounter the same problem
                                  Didn't notice this until now... :s
                                  What does it mean that "material editor is always stuck on 1 material"? I'm really not sure what is being described here. Any screenshots? Sample model?
                                  • I Offline
                                    itsupport
                                    Many thanks ! πŸ˜„
                                    Ello, have you any thoughts about this, I hope it's clearer to understand, but pelase let know if I've not made it clear.
                                    Kind Regards πŸ˜„
                                    • I Offline
                                      itsupport
                                      No Worries,
                                      Got it sorted, we wrote a little program to open your plugin's first, and also to not allow V-Ray plugin to open so that your excellent programs control it by default.
                                      Cheers
                                      • maeglin1M Offline
                                        maeglin1
                                        For me this is the best tool ever. Saved me alot of frustration and stress with all the Vray issues. A BIG Thankyou πŸ˜„
                                          sanjaygrg
                                          Hi everybody,
                                          I installed TTLib v2.9.9 and ttvray tools v2.2.1 (sketchup 8, vray for SU 2), I can't find the camera tools in vray camera tool toolbar. My question is whether camera tool is not available in vray for SU ver. 2.
                                          • tt_suT Offline
                                            tt_su
                                            Should be there... what does your toolbar look like?
                                            • 11
                                            • 12
                                            • 10 / 12
