    Conductor Heads, Downspouts and Splashblock (Gutters)
    9 Posts 7 Posters 3.2k Views 7 Watching
    • Gus RG Offline
      Gus R
      Free to good home.
      Conductor heads, downspouts and concrete splashblocks. Also includes wall brackets.
      These are for a 24 inch overhang but the first downspout can be stretched to meet your requirements as does the height of the downspout.
      This includes a copper texture.
      conductor heads and downspouts.skp
      Gutter profile is heavy on the LOD so if you use it consider cutting down on the line work.
      ➑ Update
      Added five new conductor heads only for your use.
      robatto - misc conductor heads.skp
      Skp file is under 2 MB. Smallest component is around 280KB.
      Gus
      ➑ Update
      Added another file which includes: nozzle, gutter hanger, two different downspout straps, 4 inch gutter piece with end caps, 15/75 elbows (3 and 4 inch), and downspouts (3 and 4 inch).
      Also includes a tweaked "Chancellor" conductor head.
      robatto - misc conductor heads 2.skp
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        bytor
        Very Nicely Detailed!
        Thanks Gus πŸ‘
        Find the Cost of Freedom.....
          mike d
          thanks looks good
          The grass is always GREENER on the roof.
          • Gus RG Offline
            Gus R
            Thank you Dean. Mike.
            I added 5 new conductor heads as noted in the original post above.
            Gus
              sepo
              These are nice, what we would call in UK, Heritage Hopper Heads. Thanks very much ...I can seen them being used on listed buildings.
              • jim smithJ Offline
                jim smith
                Thank you Gus - nice after Christmas present. They have found a good home and will be used well.
                "Out of clutter find simplicity,
                from discord find harmony,
                In the middle of difficulty lies opportunity"
                Albert Einstein
                • Gus RG Offline
                  Gus R
                  Thank you Sepo and Jim. Jim, I guess that was the idea since it is (was) the holiday season. Sepo, thanks for the tip on the naming in the UK. I did a search on "hopper heads" and came up with a great deal more samples and basically works of art. A couple of other names includes leaderheads and collector boxes.
                  I added another new file above with an assortment of other parts including a 4 inch nozzle (or spout). I did a mock up of a typical installation for this in 3 sections including one for a parapet. The two on the left are shown with a 24 inch overhangs while the center is with a 3 inch diameter downspout. Some of it is a bit heavy on the LOD so use it wisely for larger projects.
                  Gus
                  • Gus RG Offline
                    Gus R
                    You're welcome Modelhead. I'll try to add things here from time to time. πŸ˜„
                    • P Offline
                      Phillip
                      Gus, these works are beautiful.
                      " - USE AT YOUR OWN RISK - "
