    3d form gives error when trying to slice along X axis
    2 Posts 2 Posters 640 Views 2 Watching
    • A
      asteronimo
      Hello,
      I tried to slice the attached object along the X-axis with TIG's Slicer script.
      It does the job, gives the error "There is NO Volume to Slice!" and then undoes the slicing again.
      Any ideas what's wrong?
      I used:
      Slice spacing: 100mm
      Slice thickness: 0mm
      Slice orientation: X
      OS: Mac OSX
      SketchUp version: 7
      It gives no problem when trying to slice along the Z-axis.
      • asteronimo
      form_to_be_sliced.skp
      • TIGT
        I don't have access to v7 right now - it's safest to upload v6 or lower...
        To form volumes the slices need to make edges that form a loop that can face. If you have a box with an open top it will slice in the Z because each cut takes in 4 sides and makes a loop that forms a face.
        If the slices are done on another axis then you'll only cut through 3 sides and these 3 edges don't make a loop and therefore won't face, and therefore don't make a sliceable volume.
        To fix it give the box a'lid' and it'll then slice OK on any axis.
