    Dngbat detail
    4 Posts 4 Posters 761 Views 4 Watching
    • C
      cosycat
      I've been trying to find some easy way for my students to add surface detail to their models and hit on the of using dingbats as 3d text - no doubt you've all done this before but I thought it was quite neat.
      Anyway, this is a quick Podium render of an experimental piece using a celtic dingbat font
      http://www.alcester.net/img/balcony1.jpg
      I like the shadow detail in this and thought it could have other uses
      • TIGT
        A clever use of 3D Text.
        A quick www trawl lists loads of dingbat, celtic, art-deco, classical and other 'frieze' fonts that are specifically designed to do just in 2D what you've thought of in 3D - many are free or have 'samples'...
        Good thinking...
        • P
          pav_3j
          this is some fantastic sideways thinking.
          thanks for the tip!
          Pav
          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          • AnssiA
            Anssi
            A great idea, but as a word of warning, if you need to use a lot of these, the polycount of your model will grow quite fast, so in most cases I would recommend using textures, with or without alpha transparency. Of course, this one casts very beautiful shadows...
            Anssi
