    ActiveX error when opening Generate Report
    7 Posts 2 Posters 1.9k Views 2 Watching
      When I choose Generate Report I get a message that one or more activeX controls could not be run. (The message is in Norweigan so I don't know what it'd be exactly in English.)
      the message says that I might be blocking activeX controls due to my security settings or that I've blocked the publisher.
      anyone knows how to fix this?
        And on my home computer I get 404 message... 😞
          Welcome to Scandinavia, Tom: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=14774
          Do you think it would be worth merging the two topics (I would move this to the bug reports to merge it with the one of the Finnish).
            Thanks for points out that topic.
            But I think this can remain a separate report as I initially had activeX problems. I think it's two different issues. I'll post my problems with the 404 messages in that other thread though.
              Okay,leave separate - still moved to the Bug reports if you don't mind...
                Yup, that's good. Hopefully someone with a solution spots it here. Thanks.
                  I did the workaround mentioned in this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=14774 And I now get the Generate Report on this machine as well.
