ActiveX error when opening Generate Report
When I choose Generate Report I get a message that one or more activeX controls could not be run. (The message is in Norweigan so I don't know what it'd be exactly in English.)
the message says that I might be blocking activeX controls due to my security settings or that I've blocked the publisher.
anyone knows how to fix this?
And on my home computer I get 404 message...
Welcome to Scandinavia, Tom: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=14774
Do you think it would be worth merging the two topics (I would move this to the bug reports to merge it with the one of the Finnish). -
Thanks for points out that topic.
But I think this can remain a separate report as I initially had activeX problems. I think it's two different issues. I'll post my problems with the 404 messages in that other thread though.
Okay,leave separate - still moved to the Bug reports if you don't mind...
Yup, that's good. Hopefully someone with a solution spots it here. Thanks.
I did the workaround mentioned in this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=14774 And I now get the Generate Report on this machine as well.
