    Help building a hull.
    10 Posts 6 Posters 1.9k Views 6 Watching
    • C
      Capt. Lindemann
      Hello, I need some instructions (step by step if possible)on how to build this hull. I have tried and tried and tried, but to no avail. I can build everything else, I just cannot get the hull to look right. It is just too difficult for me. Here is some pictures so you can see what I am trying to build:
      http://www.calpoly.edu/~cpatsea/images/tsgb.jpg
      http://www.csum.edu/et/Drydock9.jpg
      http://www.csum.edu/et/Drydock10.jpg
      http://www.csum.edu/et/Drydock11.jpg
      http://www.csum.edu/et/Drydock12.jpg
      http://www.csum.edu/et/Drydock13.jpg
      http://www.csum.edu/et/Drydock14.jpg
      http://www.csum.edu/et/Drydock16.jpg
      http://www.csum.edu/et/Drydock17.jpg
      And a profile picture:
      http://upload.wikimedia.org/wikipedia/en/4/46/Golden_bear.jpg
      I do plan to place this in a simulator, so I cannot use to many pollys.
      • A
        amsterdamn
        Have you tried the "Soap Skin & Bubble" plugin?
        If not, check it out: www.tensile-structures.de
        • TaffGochT
          TaffGoch
          Captain,
          "Tom" has a couple of demonstration models in the 3D Warehouse, on how to "stitch" together a boat hull, using cross-sections:
          http://sketchup.google.com/3dwarehouse/details?mid=c0806816ff7970c6371328a2aef066d1
          http://sketchup.google.com/3dwarehouse/details?mid=730bf0073f4c6cb99d5720350d3897f5
          Aircraft fuselages are often modeled with the same technique:
          http://sketchup.google.com/3dwarehouse/details?mid=6d50fae225b9a37d3783bb821a0d6b6c
          http://sketchup.google.com/3dwarehouse/details?mid=bfe2089b01555507802d4395fd3064f8
          Alternately, you can use the "SketchyFFD" (Free-Form Deform) plugin to shape the hull, starting with a gridded rectangular block, similar to the image Pilou posted here:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6029&start=195#p113383
          ...and there is the "Soap, Skin & Bubble" plugin, to which amsterdam refers:
          http://www.tensile-structures.de/sb_examples.html
          (example step-by-step boat hull images)
          Regards,
          Taff
          "Information is not knowledge." -- Albert Einstein
          • TaffGochT
            TaffGoch
            Another discussion in the SCF,...
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=9652
            ...with a tutorial model demonstrating the use of SS&B (Soap, Skin & Bubble)
            ...and a couple of external programs for hull design, producing results that can be imported into SketchUp:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=169&t=14719
            • C
              Capt. Lindemann
              Pardon my inexpirence, but how does one install a plug-in, the soap bubble one for example.
              • R
                remus
                Download it, then move it to your plugins folder (c->program files->google->sketchup 6/7->plugins)
                • D
                  dylan
                  Most plugins are downloaded directly into your Plugins Folder: C/Program Files/Google/Google Sketchup 7/Plugins
                  If I remember correctly, SSB goes in the Tools folder after extraction. It does tell you on the SSB website.
                  http://dmdarchitecture.co.uk/
                  • C
                    Capt. Lindemann
                    That's what I was missing, thanks for the help.
                    • soloS
                      solo
                      Another way to generate a basic hull shape is to use Intersections or 'booltools' (soon to be released ruby by Whaat which automatically does the intersection and deletes the unwanted geometry)
                      I used Google and found a small blue print of a basic boat (not a great source I'm afraid) and set up for tracing.
                      http://img355.imageshack.us/img355/6957/hull1ef5.jpg
                      Next I traced out the profile (notice I only did half boat as I wanted symetry and to keep poly's low)
                      http://img357.imageshack.us/img357/1358/hull2nw6.jpg
                      Once my tracing is done I colored the sections (to make viewing easier) and grouped them seperately
                      http://img372.imageshack.us/img372/7070/hull3vn3.jpg
                      Now this is the important part, I pulled all three groups so that they totally intersect one another. Now you need to intersect them and remove the
                      geometry you do not need, I used 'booltools for this one as it's only three clicks instead of a lot of erasing manually.
                      http://img357.imageshack.us/img357/4276/hull4uq7.jpg
                      Now you have a basic shape and you can start working on the details (i made the 1st half a component and duplicated and mirrored it so that you only need to edit one side)
                      http://img355.imageshack.us/img355/3436/hull5xe1.jpg
                      Hope this helps
                      http://www.solos-art.com
                      • soloS
                        solo
                        Then there is the 'sandbox' way.
                        Create your basic shape, remove all faces leaving the line work only, then select all and use the 'from contour' option.
                        There will be some cleanup needed, but generally it should work just fine.
                        [flash=500,344:3t06z6lg]http://vimeo.com/moogaloop.swf?clip_id=2560419&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3t06z6lg]
                        http://www.vimeo.com/2560419
                        http://img375.imageshack.us/img375/4682/lehullqe9.jpg
