    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Selection Toys
    594 Posts 121 Posters 376.8k Views 121 Watching
      jmmad
      Thxs Thomas this plugin is a must ๐Ÿ˜„
      Get Upa !
        Added selection methods for Dynamic Components. Same as regular components, except it allows you to select by DC family.
          Fixed an issue where the DC menu would not appear if there was only one instance of the DC variant.
          • cmeedC Offline
            cmeed
            Does your selection tools, or is it possible in general, to select an adjacent edge after selecting a single edge in an exploded curve? then the next and so on by clicking (with your 'tool' selected) arbitrarily rather than finding little edges, zooming in clicking, paning clicking etc - finally the curve is completely selected or as much of it as you want, you can use weld.
            this would help with complex models and tight spaces.
            c
              c
              Not currently. But it's something I have on my todo list.
              • cmeedC Offline
                cmeed
                it would make a nice accompaniment to the weld tool.
                • simon le bonS Offline
                  simon le bon
                  Hey Thomas ๐Ÿ˜Ž ,
                  Native Selection tool of SketchUp is at the same time so powerfull and so poor. Your "Toys" increase incredibly its possibilities. I have had not to use those, concerning selection with components or groups for now but,
                  The idea of your "Select Loop" is really amazing (and time saver)! I like it a lot ๐Ÿ‘
                  But more and moreover what seems especially important to me is your "Selection Modifier" : which makes possible to make a new selection into an existing selection. Since the beginning i'm using SU, i think it's something which definitively misses as a native option !!!!
                  Here with this work, I discover you as a masterclass rubymaker ๐Ÿ˜ฎ ๐Ÿ‘ ๐Ÿ‘
                  ,simon
                    Reorganized the menu item for the selection filters. Now split into one Select Only->... and Deselect->....
                    The list of filters where getting too large, so I felt it was better to split them. Sorry to anyone who might have to reassign their hotkeys.
                    Added support for dimension objects and images.
                    Added support for soft and smooth edges.
                    Added support for hidden entities.
                    Added extended support for selecting faces; parallel, perpendicular, opposite and by area.
                      a4chitect
                      very good job thomthom ๐Ÿ˜‰
                      minor suggestion: consider adding a 'Deselect All' option for the Tools or Plugins menu, found this handy to assign to a keyboard shortcut to quickly get rid of the selection.
                      def self.deselect_all
                      		Sketchup.active_model.selection.clear
                        That's interesting... no Deselect All function built in to SU.
                        I'll include it for the next release. Thanks for the tip. ๐Ÿ‘
                          remus
                          Its already there. edit->select none or ctrl+t by default.
                            Matt666
                            CTRl+T deselect current selection...
                            Frenglish at its best !
                            My scripts
                              JGA
                              Is the deselect not Edit\Select None (CTRL+T)?
                              Regards,
                              JGA
                                heh ๐Ÿ˜„ then it's not included in the next release ๐Ÿ˜‰
                                • mitcorbM Offline
                                  mitcorb
                                  Thanks, thomthom:
                                  I will check this out.
                                  • majidM Online
                                    majid
                                    thanx thanx and thanx again tomtom...
                                    I've been read this tread but thought that it wouldn't be needed .... but recently i'v recieved a file that is done by someone that really is textured badly ( i mean it is textured to groups, not faces inside them) and is using lots of similar group instead of component, ... so your job is really time concuming and worthy .... ๐Ÿ˜
                                      Another small update:
                                      • Optimized code that's using .typename
                                      • Added Select Face Same Direction
                                      • Added workaround for SU bug where group definition references becomes corrupted.
                                        Added filters for Curves (Polylines)
                                        Before Arcs would select Curves and Arcs and Circles - Now they select Arcs and Circles
                                        Curves will select Curves, Arcs and Circles.
                                        Question:
                                        Currently, Curves selects Arcs and Circles are a subset of Curves.
                                        But is it preferred that Curves selects only Curves - Arcs only Arcs and Circles selects only Circles?
                                          ThomThom, takk for alt.
                                          Could you do a little favor? When you update a plugin, could you add the date of the update to the title line? I can't remember version numbers well enough to recognize and update has been issued. I usually can't remember the date ,either. But I know enough to hover the cursor over the clock on my computer screen to find out what the current date actually is.
                                          Thank you.
                                            Done!
                                            • 29
                                            • 30
                                            • 3 / 30
