    [Plugin] Selection Toys
    594 Posts 121 Posters 498.8k Views 121 Watching
      Reorganized the menu item for the selection filters. Now split into one Select Only->... and Deselect->....
      The list of filters where getting too large, so I felt it was better to split them. Sorry to anyone who might have to reassign their hotkeys.
      Added support for dimension objects and images.
      Added support for soft and smooth edges.
      Added support for hidden entities.
      Added extended support for selecting faces; parallel, perpendicular, opposite and by area.
        a4chitect
        very good job thomthom 😉
        minor suggestion: consider adding a 'Deselect All' option for the Tools or Plugins menu, found this handy to assign to a keyboard shortcut to quickly get rid of the selection.
        def self.deselect_all
        		Sketchup.active_model.selection.clear
          That's interesting... no Deselect All function built in to SU.
          I'll include it for the next release. Thanks for the tip. 👍
            remus
            Its already there. edit->select none or ctrl+t by default.
              Matt666
              CTRl+T deselect current selection...
              Frenglish at its best !
              My scripts
                JGA
                Is the deselect not Edit\Select None (CTRL+T)?
                Regards,
                JGA
                  heh 😄 then it's not included in the next release 😉
                  • mitcorbM Offline
                    mitcorb
                    Thanks, thomthom:
                    I will check this out.
                    • majidM Offline
                      majid
                      thanx thanx and thanx again tomtom...
                      I've been read this tread but thought that it wouldn't be needed .... but recently i'v recieved a file that is done by someone that really is textured badly ( i mean it is textured to groups, not faces inside them) and is using lots of similar group instead of component, ... so your job is really time concuming and worthy .... 😍
                        Another small update:
                        • Optimized code that's using .typename
                        • Added Select Face Same Direction
                        • Added workaround for SU bug where group definition references becomes corrupted.
                          Added filters for Curves (Polylines)
                          Before Arcs would select Curves and Arcs and Circles - Now they select Arcs and Circles
                          Curves will select Curves, Arcs and Circles.
                          Question:
                          Currently, Curves selects Arcs and Circles are a subset of Curves.
                          But is it preferred that Curves selects only Curves - Arcs only Arcs and Circles selects only Circles?
                            ThomThom, takk for alt.
                            Could you do a little favor? When you update a plugin, could you add the date of the update to the title line? I can't remember version numbers well enough to recognize and update has been issued. I usually can't remember the date ,either. But I know enough to hover the cursor over the clock on my computer screen to find out what the current date actually is.
                            Thank you.
                              Done!
                                You're a champ!
                                • mitcorbM Offline
                                  mitcorb
                                  Thomthom:
                                  I would make a suggestion here.
                                  I think the title of this ruby should be Thomthom Selection Toys, in your own honor and ownership.
                                  You have advanced Sketchup to a new level here!
                                  Thank you.
                                  • mitcorbM Offline
                                    mitcorb
                                    hmmm. perhaps my last post here was a bit effusive and over the top. excuse me.
                                    • Chris FullmerC Offline
                                      Too effusive? No such thing around here!
                                        heh, no worries. I'm glad you liked it.
                                        • mitcorbM Offline
                                          mitcorb
                                          Well, then, you guys must have been napping. And I reinstate what I said about naming that plugin.
                                          Best Regards,
                                          mitcorb
                                            I think I'll keep the name as it is. But I do accept donations in the shape of cookies*. 😉
                                            *** Cookies can be replaced with beer. (Excluding white beer and Budweiser and Spitfire).**
                                            • 29
                                            • 30
                                            • 3 / 30
