    [Plugin] Selection Toys
    594 Posts 121 Posters 495.5k Views 121 Watching
      would be awesome if you could add a "select all connected" command ..
      As Dave mention that is a native function:
      ...or you can triple click.
        dedmin
        Win 7 64 bit, SU 2014 Pro (latest update)
        See the video.
        Video_2014-06-07_080026.wmv
          Any errors in the Ruby Console?
            dedmin
            Nope.
            selection_toys.7z
              All look at it when I get back from my vacation that starts now. I'll be gone for two week cycling - with little or no internet access.
                bruorlando
                Hi Thom,
                This script helps me so much in my everyday work I have no words to thank you enough.
                I'm writing, though, trying to solve a bug I just can't figured out where it came from. Although the script works for every type of selection, it no longer runs for LINEAR DIMENSIONS. Not via the toolbar, nor contextual menu.
                I've tried reinstalling the plugin, updating the software (14.1.1283), but so far, that one remains "mute".
                Has anyone faced similar problem?
                Do you have any suggestions?
                Thanks in advance.
                Bruno
                • Dan RathbunD Offline
                  Dan Rathbun
                  The exposure of dimension objects changed in the Ruby API for SU2014.
                  Do you have the latest version of of Selection Toys ?
                  I'm not here much anymore.
                    Ah, yes - new classes where introduced in SU2014. I'll have to fix that.
                      Fix live on EW. Found a couple of other small bugs that I need to fix in another update. Will post that soon and make sure to update on PluginStore as well.
                      • plot-parisP Offline
                        plot-paris
                        I have a selection question. I guess if any plugin can help me, it is this one. But I am not sure how. Maybe someone can help me.
                        I have this model with many (non-quad) faces. And I would like to soften all the triangulation-edges so that I am left with seemingly quad faces.
                        I guess the best way would be to soften everything, then select the edge loops and unsoften them. But I don't know how.
                        Is it possible at all with this plugin?
                        If yes, how?
                        Any help would be appreciated.
                        Cheers,
                        Jakob
                          It's unpredictable to try to determine the diagonals of pseudo-quads. I've tried but what is easy to our eyes is not easy to a script.
                          How did you create that mesh btw? Several extensions have support for QuadFace tools. which will create what you want.
                            jumpjack
                            I can't understand if and how I can use this plugin to select only edges delimiting holes inside a surface, rather than also external edges of the surface itself.
                            For example, in this case:
                            I want only this selection:
                            • pbacotP Offline
                              You might be able to select those edges more easily if you soften/smooth the surface first.
                                Indeed! And then you could probably drag a selection box around the edges of the hole to select the edges. No plugin needed.
                                  jumpjack
                                  This is only a small part of a very large model, it would take years to edit all holes by hand:
                                  http://sketchucation.com/forums/download/file.php?id=124357&t=1
                                  That's why I'm looking for some automation.
                                    Right Click > Select Only > Border Edges
                                    • josephkim626J Offline
                                      josephkim626
                                      For some reason, "Select Coplanar Faces" results some other parallel faces selected that aren't necessarily "Coplanar"?
                                        Could you post an example SKP file that exhibits this behavior?
                                        And please complete your profile with SketchUp version and operating system.
                                        • tt_suT Offline
                                          tt_su
                                          The menu name is misleading - it's Same Direction instead of truly coplanar.
                                            josephkim626
                                            Sorry, it is tested on windows 7 and sketchup 2014 (in different machines)
                                            Red circled face was the face that was used to execute "select coplanar face"
                                            example
                                            skp file
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 26 / 30
