    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
    • C
      caronte01
      Hi all.
      Yes, I use dropbox to sync my plugins folder between 2 computers, 1 windows pc that I use at work, and a macbook that I have at home. I've had no issues with this system so far. Almost all plugins work ok, the few that don't, I install locally.
      I had compatibility problems between podium 2 and 000_AdditionalPluginFolders, but uninstalled podium and everything went back to normal.
      No, I don't have organizer installed.
      • C
        caronte01
        BTW, Happy holidays!
        • thomthomT
          Can you try, just for the sake of it an place Selection Toys and TT_Lib into the actual plugins folder and see if that avoids the errors. Then we'd know if it works without Additional Folders handling this.
          • C
            caronte01
            Hi ThomThom.
            Test 1: Moved TT_Lib and selection toys to the native plugin folder, left everything else untouched. Got this error:
            Test 1
            Test 2: Moved TT_Lib and selection toys to the native plugin folder, removed 000_AdditionalPluginFolders. Selection toys loaded correctly.
            Test 2
            Test 3: TT_lib, selection toys and 000_AdditionalPluginFolders in the native plugins folder, dropbox folder left empty. Got this error:
            Test 3
            Test 4: Just in case, 000_AdditionalPluginFolders in the native directory, TTlib and selection toys in my dropbox plugin folder Error:
            Test 4
            So it is some kind of incompatibility with this two plugins?
            • thomthomT
              Hmm... need to check with Fredo on this.
                In a case like that, you might be better off deleting all of the layers and putting everything back on Layer 0. Then start over with making layer associations.
                • gonashviliG
                  gonashvili
                  Is there a way to select everything within a particular layer?
                  I've got big mess, components within components with each of them on various layers and I'd like to clean up, reduce the number of layers. It would help to 'see' whats on a particular layer....
                  I mean when I try to remove a layer thinking its empty, the dialog appears [wants to move the contents] and often times I have no idea where to look for them as unclicking the 'Visible' box in the Layers dialog might make it seem like its empty/there's no change, visually...
                  Cheers
                  • gonashviliG
                    gonashvili
                    Guess you're right, such a feature would rule though, I think
                    • thomthomT
                      "Select all on Selected Layer" - That means the layer the selected entity is on.
                      • thomthomT
                        Version 2.2.2
                        • Added Select Active with Materials
                        • Removed dependency from TT_Lib
                        • Repackaged as RBZ
                        • cottyC
                          cotty
                          Thank you for the update.
                          (I will not ask how to install it πŸ˜‰ )
                          my SketchUp gallery
                          • C
                            caronte01
                            Hi Thomas,
                            Installed the new version. It now works, no conflicts or errors!
                            Thanks a lot!
                            Santiago
                            • M
                              Mra
                              Thanks for the amazing plugin. I was wondering if for future that some extra things could be implemented although I ponder if this is impossible with SketchUp.
                              Basically Maya has some sweet tools in this regard;
                              Select an edge ring
                              Select a path of edges between two edges
                              Invalid URL
                              (download.autodesk.com)
                              Just an idea.
                              • D
                                driven
                                like TT other plugin?
                                [web 100%,600:uxxl934f]http://www.thomthom.net/software/vertex_tools/[/web:uxxl934f]
                                john
                                • thomthomT
                                  Select an edge ring
                                  Invalid URL
                                  Just an idea.
                                  Check out QuadFace Tools: http://extensions.sketchup.com/en/content/quadface-tools
                                  It doesn't have Select path between two edges yes, but it's on the todo list.
                                  • C
                                    clubber2k
                                    Is there, or will there be, a select all "seemingly" connected segments (lines)?
                                    when you have a few lines on a complex component and you want to select all of the connected ones you touch but not all the lines and not the faces.
                                    double clicking a line when theres no face selects all the lines but double clicking a line when on face selects the face as well and all lines around. I'd like to be able to select all the connected lines and nothing else..
                                    thanks!
                                    • cottyC
                                      cotty
                                      What about double click and deselect the unwanted face(s)?
                                      my SketchUp gallery
                                      • C
                                        clubber2k
                                        too tedious if you have like 100 faces and you only want the lines..
                                          Switch to wire view and select only the edges.
                                          • cottyC
                                            cotty
                                            You can use the selection toys (this topic πŸ˜‰ ) for this...
                                            my SketchUp gallery
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 29
                                            • 30
                                            • 24 / 30
