    RpTreeMaker - new version Dec 12, 2008
    extensions
    67 Posts 15 Posters 11.1k Views 15 Watching
    • Al HartA Offline
      Al Hart
      @earthmover said:
      Al,
      When you say "holes", do you mean in the shadow mask?
      Holes in the tree, which should also create holes in the shadow mask so light can pass through the tree.
      Al Hart
      IRender nXt from Render Plus
      • AnssiA Offline
        Anssi
        Thank you very much AL,
        What a versatile tool this has become!
        Anssi
          tomasz
          @al hart said:
          Also, send me a sample of a KT compatible proxy object. RpTools has a tool which creates proxy objects. I have attached one. Let me know what changes I need to make to make it compatible with KT.
          We are looking at an option to create 3D trees, but haven't had a chance to do it yet.
          Hi Al,
          Thanks for models and new version. Will try it and come back with comments.
          I have done proxy objects in SU2KT following way: There are two components Tree1 and Tree1_HIGHPOLY.
          The highpoly has an attibute set pointing to lowpoly (component name):
          highpoly_definition.set_attribute("su2kt","high_poly",su_lowpoly_comp.definition.name)
          That is mainly it.
          It lets an user to place components on whatever layer they want.
          I am glad you consider exporting 3D trees is a future!
          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          • Al HartA Offline
            Al Hart
            Doesn't this have the problem that if a user selects Purge then one of the components disappears - or does the user place both in the drawing and turn off one of the layers,
            Does the low poly component point the high polu component as well?
            We wound putting the High Poly and Low poly geometry in the same component (option A), or having the low poly component include an instance of the high-poly component in a layer (option B)
            Al Hart
              me3mar
              FIRST OF ALL THANKS SOOOOO MUCH FOR THE GREAT TOOL,
              i would like to ask about rendering with vray, is there a specific way to do it ? i just tried and got a black shadow surrounding the whole tree, is there any trick to do ?
              thanks in advance
                me3mar
                i just found it out , sorry
                • Al HartA Offline
                  Al Hart
                  Al, I had downloaded the RpTreeMaker - The one big problem I see with it, is that the trees don't cast shadows (or have I missed a step?). Please let me know if I am doing something wrong, or if you get that fixed.
                  The latest version should cast shadows in SketchUp. We added a shadow mask to cast shadows.
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    thanks in advance
                    Note: There is a setting on the advanced settings dialog to create an alpha clipmask for VRay. You can export it from the SketchUp Materials Wizard.
                    http://wiki.renderplus.com/images/8/8a/Advanced_Settings.jpg
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      We put out a new version today.
                      • Added ability to set the camera height as a percentage of the tree height.
                      • Added shadow masks so trees cast realistic shadows in SketchUp
                      • Used faces so trees render more easily in Podium
                      • Added clipmask for easier rendering with VRay (Of course the trees render easily, and better, with IRender)
                      Batch Mode
                      The version has a Batch mode, for those people who have been having problems executing it from SketchUp. See: Batch Mode
                      Shadows masks in sketchUp
                      http://wiki.renderplus.com/images/3/30/RpTreeMaker-shadows.jpg
                      Al Hart
                        chango70
                        This is brilliant! Yon've even thought of VRay! 😍
                          me3mar
                          it works perfectly 😄 thank you ao much...
                          is this a free plugin ? or is it yet just a beta vergin?
                          thanks in advance
                            me3mar
                            LOOOOOOOL that was pretty funny, thanks AL for the great plugin and the great " Virgin" Imagination 😉
                            greetings
                            me3mar
                            • Al HartA Offline
                              Al Hart
                              thanks in advance
                              RpTreeMaker is going to remain a free plugin. But we could offer a Pro version someday. (for $$). (We don't believe we should announce a product as free, and change out mind later - although this could always happen - especially if we get gobbled up by a large, greedy (and hopefully with deep pockets) conglomerate. (And of course, "free" is a different phrase than "free trial".)
                              RPS is offering some of it products free, (RpTreeMaker, RpEdits, ProjectSketch and the free version of RpWalls - which we hope to beta next week). We think we get good feedback from a wider audience from the free versions, and hopefully the free versions will inspire some SketchUp users to purchase our other products. (For instance RpTreeMaker works pretty well with the other add-on renderers, but works even better with IRender. Also, RpEdits has some useful tools, but RpTools has ever more.)
                              (I'm not sure if the word you used - "vergin" - was a misspelling of "version", or a clever play on words based on the word "virgin" 😄 - meaning that we were trying to trap virgins into using it and then surprising them later when it turned out not to be free after all. )
                              Al Hart
                              • EarthMoverE Offline
                                EarthMover
                                Al,
                                Just tried out the newest version and it's a lot better. I'm really happy with the results. A couple things though.
                                1. It would be nice to have some control over the secondary branching. Even at Max fullness, the secondary branching remains disproportionate to what occurs in nature. The off shoot branching should be fuller and vary in direction depending on the type of specimen. Control of secondary branching would help to achieve a higher level of realism.
                                2. Control over the central leader. Most deciduous trees don't have the same central leader structure as a conifer, where the main trunk extends to the top. The central leader will generally split into branching off shoots at the crotch, long before the top of the tree. This is true especially as deciduous trees mature. In the editor however, for standard trees, the central leader is always extending to the top of the tree. It works for some trees, like Oak for instance, but for others, I have a hard time creating the proper branching structure. Take this Zelcova Serrata for instance. Notice the central leader vs. branching structure -
                                  http://img216.imageshack.us/img216/8316/25ingreenvasezelcovamvcoo8.jpg
                                3. Lastly, I was wondering if it were possible to allow an option to create an NPR version of the tree? Something that will be read in a B&W sketchy line style. I tried playing around with unhiding the lines that are around the shadow mask, and this works okay, but it would be great if some of the branching was also translated into line work. I know this may be pushing it, but it's worth a shot.
                                Content Creator at Skapeup
                                • Al HartA Offline
                                  Al Hart
                                  @earthmover said:
                                  Al,
                                  I passed your comments on to the author. He is working on shrubs and such and perhaps that will help.
                                  I'm trying to think of a good way to get edge lines for the trunk and branches. I think the only way to make this work will be to create a 3D tree with edges. Then the Sketchy Edges should just work. However, this will probably be in the "Pro" version, rather than the free version.
                                  I tried some Sketchy edges on cylinders and they work OK. So if I can create geometry for the branches and leaves, we should be able to get a NPR effect.
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    I am an ex Forest Ranger and always wanted to try creating fractal trees.
                                    I have downloaded RPtreemaker.
                                    Yes I have used it a lot in the last week and think its excellent.
                                    The program is simple to use but I do get confused between the functions of
                                    bend and horizontal.
                                    I do have some ideas.
                                    I think the trees would be more realistic if there was some randomness
                                    generated between multiple trunks. Most trees with multiple trunks have each
                                    trunk start at different height and with different diameters. I notice that
                                    in the standard type currently multiple trunks are duplicates all starting
                                    at the same height.
                                    It would be great to have a control or two that addressed this issue.
                                    Another factor of reality would be windage. Many locations cause trees to
                                    grow more out one side than the other. The trunk at ground level is not in
                                    the centre of the dripline and the tree ends up asymmetric. A windage
                                    control could address this issue.
                                    I am enjoying using your software and particularly like the uniformity it
                                    gives with the trees in my models. Please keep up the great work.
                                    Thanks for the comments - I will pass them on to the developer, and hopefully he will incorporate some of them in future versions.
                                    Al Hart
                                    • X Offline
                                      xrok1
                                      sure would be nice if i could get past 100k of the 40 meg download?? 😲
                                      looks like a great prog. but please fix the download link i've tried about 20 times now and can't get more than 100k or so of the file then it pauses and times out?
                                      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                      • X Offline
                                        xrok1
                                        i used bitcomet with 10 connections and finally got it downloaded now when i try to extract it the .zip file is corrupt?????????
                                        • Al HartA Offline
                                          Al Hart
                                          sounds like you are having download problems.
                                          Please try again later. Something may be wrong with a site or connection somewhere.
                                          Al Hart
                                          • X Offline
                                            xrok1
                                            deleted file and downloaded again, i still get "can't open file as archive message" from 7zip and zip file corrupt message from winrar??????????
                                            • 3 / 4
