    RpTreeMaker - new version Dec 12, 2008
    extensions
    67 Posts 15 Posters 14.0k Views 15 Watching
    • Al HartA Offline
      Al Hart
      Give it another try at: RpTreeMaker HL12tm
      I was able to download it OK today.
      Perhaps someone else can try.
      Al Hart
      IRender nXt from Render Plus
        tomasz
        Hi Al,
        Thank you for a brilliant tool.
        I have rendered the group of trees in Kerkythea.
        I had to modify one thing in your model. Image map is applied to Back Face instead of Front.
        I have an idea. Al, would it be possible to export full 3D model from your app as well.
        What I am thinking of is having a 2D tree in SU and then full 3D model in a rendering application as instanced object! It would be an excellent feature.
        I have already implemented it in SU2KT where there is a hidden, high polygon component and a simplified proxy just for SU. Maxwell, Fryrender, Indigo, Kerkythea and other application users would be extremely happy to see it.
        Cheers
        Tomasz
        Trees rendered in Kerkythea. PNG applied to front faces as well.
        SU2KT sample - left side=proxy, right side=rendering
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        • jujuJ Offline
          juju
          Hi Al, thanks for the reply. I was finally able to download the app, the transfer went dead a few times but I got it DL'ed and extracted fine. Seems like the trouble must have been on my end seeing that nobody else seem to be having trouble.
          Now, to try the app out!
          • Al HartA Offline
            Al Hart
            Hi Al,
            Cheers
            Tomasz
            Tomasz, I had attempted to put the image map on bot sides of the tree.
            Take the attached tree, and return it to me with any changes you needed to make to get it to work with KT.
            tree with texture image on both sides
            SKP model with two-sided face tree, and image palm tree.
            (The attached tree also has a palm tree created as an image, rather than a face. Let me know if that works with KT as well.)
            Also, send me a sample of a KT compatible proxy object. RpTools has a tool which creates proxy objects. I have attached one. Let me know what changes I need to make to make it compatible with KT.
            Proxy component from RpTools
            Sample Proxy Object created with RpTools.
            Currently, we use two layers - Proxy HI-POLY and Proxy LOW-POLY to let the user switch between displays. Does KY use a different scheme to store the proxy information?
            We are looking at an option to create 3D trees, but haven't had a chance to do it yet.
            Al Hart
            • EarthMoverE Offline
              EarthMover
              Al,
              Have you considered the idea of creating a .png to .skp converter to add to your line of RP tools? It seems you already have the coding done for a tool like this. Hypothetically, this tool would allow the user to import a .png, or .tif transparent file and the converter would spit out a .skp file with the shadow mask applied. Also adding a alpha mask output would be invaluable for certain rendering users.
              Content Creator at Skapeup
              • Al HartA Offline
                Al Hart
                @earthmover said:
                Al,
                That would be a good addition to RpTools.
                I wanted to get holes working, but I hadn't gotten around to it yet. (Its the same algorithm - but applied again to the holes). I decided to release the RpTreeMaker version without holes. As I write this I can't decide whether to wait for holes or not.
                Also, RpTools already has a tool which converts a color (range of colors) in your image into an alpha channel. So it would be easy to grab the background color of images which are not alpha transparent and use them as well.
                Al Hart
                  EarthMover
                  Al,
                  When you say "holes", do you mean in the shadow mask?
                  • Al HartA Offline
                    Al Hart
                    @earthmover said:
                    Al,
                    Holes in the tree, which should also create holes in the shadow mask so light can pass through the tree.
                    Al Hart
                    • AnssiA Offline
                      Anssi
                      Thank you very much AL,
                      What a versatile tool this has become!
                      Anssi
                        tomasz
                        Hi Al,
                        Thanks for models and new version. Will try it and come back with comments.
                        I have done proxy objects in SU2KT following way: There are two components Tree1 and Tree1_HIGHPOLY.
                        The highpoly has an attibute set pointing to lowpoly (component name):
                        highpoly_definition.set_attribute("su2kt","high_poly",su_lowpoly_comp.definition.name)
                        That is mainly it.
                        It lets an user to place components on whatever layer they want.
                        I am glad you consider exporting 3D trees is a future!
                        • Al HartA Offline
                          Al Hart
                          Doesn't this have the problem that if a user selects Purge then one of the components disappears - or does the user place both in the drawing and turn off one of the layers,
                          Does the low poly component point the high polu component as well?
                          We wound putting the High Poly and Low poly geometry in the same component (option A), or having the low poly component include an instance of the high-poly component in a layer (option B)
                          Al Hart
                            me3mar
                            FIRST OF ALL THANKS SOOOOO MUCH FOR THE GREAT TOOL,
                            i would like to ask about rendering with vray, is there a specific way to do it ? i just tried and got a black shadow surrounding the whole tree, is there any trick to do ?
                            thanks in advance
                              me3mar
                              i just found it out , sorry
                              • Al HartA Offline
                                Al Hart
                                Al, I had downloaded the RpTreeMaker - The one big problem I see with it, is that the trees don't cast shadows (or have I missed a step?). Please let me know if I am doing something wrong, or if you get that fixed.
                                The latest version should cast shadows in SketchUp. We added a shadow mask to cast shadows.
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  thanks in advance
                                  Note: There is a setting on the advanced settings dialog to create an alpha clipmask for VRay. You can export it from the SketchUp Materials Wizard.
                                  http://wiki.renderplus.com/images/8/8a/Advanced_Settings.jpg
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    We put out a new version today.
                                    • Added ability to set the camera height as a percentage of the tree height.
                                    • Added shadow masks so trees cast realistic shadows in SketchUp
                                    • Used faces so trees render more easily in Podium
                                    • Added clipmask for easier rendering with VRay (Of course the trees render easily, and better, with IRender)
                                    Batch Mode
                                    The version has a Batch mode, for those people who have been having problems executing it from SketchUp. See: Batch Mode
                                    Shadows masks in sketchUp
                                    http://wiki.renderplus.com/images/3/30/RpTreeMaker-shadows.jpg
                                    Al Hart
                                      chango70
                                      This is brilliant! Yon've even thought of VRay! 😍
                                        me3mar
                                        it works perfectly 😄 thank you ao much...
                                        is this a free plugin ? or is it yet just a beta vergin?
                                        thanks in advance
                                          me3mar
                                          LOOOOOOOL that was pretty funny, thanks AL for the great plugin and the great " Virgin" Imagination 😉
                                          greetings
                                          me3mar
                                          • Al HartA Offline
                                            Al Hart
                                            thanks in advance
                                            RpTreeMaker is going to remain a free plugin. But we could offer a Pro version someday. (for $$). (We don't believe we should announce a product as free, and change out mind later - although this could always happen - especially if we get gobbled up by a large, greedy (and hopefully with deep pockets) conglomerate. (And of course, "free" is a different phrase than "free trial".)
                                            RPS is offering some of it products free, (RpTreeMaker, RpEdits, ProjectSketch and the free version of RpWalls - which we hope to beta next week). We think we get good feedback from a wider audience from the free versions, and hopefully the free versions will inspire some SketchUp users to purchase our other products. (For instance RpTreeMaker works pretty well with the other add-on renderers, but works even better with IRender. Also, RpEdits has some useful tools, but RpTools has ever more.)
                                            (I'm not sure if the word you used - "vergin" - was a misspelling of "version", or a clever play on words based on the word "virgin" 😄 - meaning that we were trying to trap virgins into using it and then surprising them later when it turned out not to be free after all. )
                                            Al Hart
                                            • 3 / 4
