    Problem with copies and layer assignment
    3 Posts 3 Posters 1.0k Views 3 Watching
    • B
      BillW
      I have a problem with copies not assigning the correct layer to copies above the first copy - see attached.
      The component below the topmost component has a layer "Structure" which contains nested components assigned to "Layer 0". The copies above 1 use the nested components layer assignment rather than their container component's layer.
      I think this is a bug. Does anyone want to confirm?
      I can fix it I think by assigning the nested components layer to "Structure"
      • D
        dagfinnie
        Yes.It seems that if you duplicate components with "COPY",they are assigned to Layer0, whatever layer the origin is attached to. It could be intended, but it's probably a bug since it's not practical to have the same components in different layers.
        • J
          JessicaWrixon Newcomers
          HEY, this is Jessica here. Came across a problem with copies about assignment help[anchor= goto=https://wwww.globalassignmenthelp.com/ca/homework-help:8z1c7e1w]homework help Canada[/anchor:8z1c7e1w], I also help students to complete their homework and help to resolve assignment problem.
