Problem with copies and layer assignment
I have a problem with copies not assigning the correct layer to copies above the first copy - see attached.
The component below the topmost component has a layer "Structure" which contains nested components assigned to "Layer 0". The copies above 1 use the nested components layer assignment rather than their container component's layer.
I think this is a bug. Does anyone want to confirm?
I can fix it I think by assigning the nested components layer to "Structure"
Yes.It seems that if you duplicate components with "COPY",they are assigned to Layer0, whatever layer the origin is attached to. It could be intended, but it's probably a bug since it's not practical to have the same components in different layers.
HEY, this is Jessica here. Came across a problem with copies about assignment help[anchor= goto=https://wwww.globalassignmenthelp.com/ca/homework-help:8z1c7e1w]homework help Canada[/anchor:8z1c7e1w], I also help students to complete their homework and help to resolve assignment problem.
