    Lighting Inside Display Cases
    8 Posts 6 Posters 1.0k Views 6 Watching
    • B
      bassboy3313
      Hey. I made my own display case and need to add lights inside to illuminate the objects. How do I go about doing this?
      • D
        Double Espresso
        You will need to import into a rendering prog. Check these out. Podium or Kerkythea.
        http://www.suplugins.com/
        http://www.kerkythea.net/joomla/index.php
        • B
          bassboy3313
          how do you import a 3D drawing from SketchUp to Kerkythea? It doesnt seem to be the correct file type.
          • R
            remus
            The easiest way to do it is with the kerkythea exporter: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/SU2KT3_0.exe
            It also does other useful things like let you set up your lighting in SU. Have a look at the getting started guide on the kerky site for a step by step guide.
            • thomthomT
              Or LightUp http://www.light-up.co.uk/
              • D
                Double Espresso
                The Kerky plugin will save it as an xml. file and ask if you want to export directly to Kerky.
                DE
                • jujuJ
                  juju
                  Don't forget that there is also Indigo and PovRAY, both for rendering light and rendering in general.
                  • S
                    ScottPara
                    404 Not Found
                    (www.sketchucation.com)
                    Or just look here and make the choice that is right for you.
                    Scott
                    Love the fact that some HATE my avatar.....
