    Lighting Inside Display Cases
    8 Posts 6 Posters 961 Views 6 Watching
    • B
      bassboy3313
      Hey. I made my own display case and need to add lights inside to illuminate the objects. How do I go about doing this?
        Double Espresso
        You will need to import into a rendering prog. Check these out. Podium or Kerkythea.
        http://www.suplugins.com/
        http://www.kerkythea.net/joomla/index.php
        • B
          bassboy3313
          how do you import a 3D drawing from SketchUp to Kerkythea? It doesnt seem to be the correct file type.
            remus
            The easiest way to do it is with the kerkythea exporter: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/SU2KT3_0.exe
            It also does other useful things like let you set up your lighting in SU. Have a look at the getting started guide on the kerky site for a step by step guide.
              Or LightUp http://www.light-up.co.uk/
                Double Espresso
                The Kerky plugin will save it as an xml. file and ask if you want to export directly to Kerky.
                DE
                • jujuJ
                  juju
                  Don't forget that there is also Indigo and PovRAY, both for rendering light and rendering in general.
                    ScottPara
                    404 Not Found
                    (www.sketchucation.com)
                    Or just look here and make the choice that is right for you.
                    Scott
                    Love the fact that some HATE my avatar.....
