    New user and first "please help me to model this". thanks
    5 Posts 4 Posters 618 Views 4 Watching
    • E
      emmebiarch72
      Hi to all SketchUp community,
      I am new to SketchUp and i have first problem to model the table legs that you see in this picture.
      http://img146.imageshack.us/img146/2717/picture1xz2.png
      Can some one give me an idea of how to proceed with it? in particular the problem is that the final cylinder part is curved an start with a bigger circle to a smaller.
      first i'll try with a "follow me" command and than separating it in various part, but with a bad result ...
      this is my bad work
      http://img518.imageshack.us/img518/8396/cilindrobq6.jpg
      http://www.emmebiarchitetture.it/public/sketchup/cilindro.skp
      if anyone can help me i would be very grateful
      thank you very much
      marco from ITALY
      • B
        BTM
        I tried.
        I think I made it a bit too fat though... should have paid more attention to the image...
        If you need it thinner, or less bent, I can make you a new one πŸ˜„
        leg.skp
        To make It, I used Sketchy FFD. search FFD on the forum to find it.
        • J
          johnsenior1973
          The tapermaker plugin will make those legs very simply. You can get it from here: http://www.drawmetal.com/tapermaker
          • TaffGochT
            TaffGoch
            Marco,
            I use the Taper Maker plugin, which will produce round (or square, etc.) curved tapers. It's a free SketchUp plugin, available here:
            This plugin should make perfect round-cross-section legs for your table.
            [ EDIT: I see johnsenior1973 beat me to it! ]
            Regards,
            Taff
            "Information is not knowledge." -- Albert Einstein
            • E
              emmebiarch72
              well thanks for all your post.
              i do the legs using the taper maker plugin: cool!
              this is my result:
              http://www.emmebiarchitetture.it/public/sketchup/final.jpg
              thank you to all sketchup community forum!
