    Mac - SKP 7 problem with exporting to dwg (2D)
    16 Posts 4 Posters 3.8k Views 4 Watching
    • O
      oski
      SketchUp Pro 7 on MAC
      I have a problem with exporting to dwg (2D). SketchUp does the work
      but no file is created. Tryed all AutoCad options and dxf. With SKP
      6 the export works fine.
      • GaieusG
        Hi Oski,
        In Window > Preferences > Files you can set the path to your exports. Is the exporter trying to export something along that path (if created) or elsewhere?
        • O
          oski
          Working on MAC so I suppose there is no PATH-settings ?
          • GaieusG
            Preferences open from the Sketchup menu on Mac (AFAIK).
            • O
              oski
              Hi Gai...
              Yes I know. But there is no settings for paths. You can set the export location when exporting.
              • GaieusG
                And are you sure you are looking for the file where you create/save it? I know stupid question but I'm a PC users and just stabbing in the dark.
                Any Mac users can chime in?
                • O
                  oski
                  Yes I scanned the whole disk. Thank's anyway for trying Gai... ☀
                  • GaieusG
                    What I guess is that maybe your installation was corrupt. Could you try a reinstall?
                    • O
                      oski
                      Done that, no effect 😒
                      Maybe I have to try to uninstall complete and then reinstall - who knows ...
                      I have also sent a message to SketchUp support let's see if they have any new suggestions.
                      I have the version 6 still installed. Hopefully that doesn't cause any problems with the new version.
                      • GaieusG
                        They can both run safely along each other.
                        • O
                          oski
                          This morning after the computer had been shut down over the night I was able to export once. After this it stopped working again 😲
                          Non-English characters tested - No effect.
                          The problem occurs with all files.
                          Using standard export settings.
                          Uninstalled and re-installed and shut down the computer - no effect.
                          Deleted the plist (com.google.sketchuppro7.plist) - no effect....
                          • O
                            oski
                            PROBLEM SOLVED
                            Sketchup 7 can't export (DWG/DXF) to folders with non-English characters. Sketchup 6 have no problems with this 😮
                            • GaieusG
                              Dammit. If I knew that I could've filed a decent bug report on it - my problem is that at home I only have an English OS and keyboard so never noticed.
                              • AnssiA
                                Anssi
                                It must be a Mac bug - I tried on my XP Home Finnish system, and I was able to export both to the desktop ("Työpöytä") and to a folder named "Hääyöaie"
                                Anssi
                                • O
                                  oski
                                  Yes propably. MAC seems to have some problems with scandinavian characters (öäå...). I have also problems with mail attachments including non-english charracters.
                                  20 nights to x-mas 🎉
                                  • snicoloS
                                    snicolo
                                    You Nailed it, this is a known issue on our part about non-English characters handling on the Mac.
                                    We are working on it.
                                    Simone.
                                    Simone Nicolo
                                    QA Manager
                                    http://www.sketchup.com
