    Mac - SKP 7 problem with exporting to dwg (2D)
    16 Posts 4 Posters 3.4k Views 4 Watching
    • O Offline
      oski
      Hi Gai...
      Yes I know. But there is no settings for paths. You can set the export location when exporting.
        And are you sure you are looking for the file where you create/save it? I know stupid question but I'm a PC users and just stabbing in the dark.
        Any Mac users can chime in?
        • O Offline
          oski
          Yes I scanned the whole disk. Thank's anyway for trying Gai... ☀
            What I guess is that maybe your installation was corrupt. Could you try a reinstall?
            • O Offline
              oski
              Done that, no effect 😒
              Maybe I have to try to uninstall complete and then reinstall - who knows ...
              I have also sent a message to SketchUp support let's see if they have any new suggestions.
              I have the version 6 still installed. Hopefully that doesn't cause any problems with the new version.
                They can both run safely along each other.
                • O Offline
                  oski
                  This morning after the computer had been shut down over the night I was able to export once. After this it stopped working again 😲
                  Non-English characters tested - No effect.
                  The problem occurs with all files.
                  Using standard export settings.
                  Uninstalled and re-installed and shut down the computer - no effect.
                  Deleted the plist (com.google.sketchuppro7.plist) - no effect....
                  • O Offline
                    oski
                    PROBLEM SOLVED
                    Sketchup 7 can't export (DWG/DXF) to folders with non-English characters. Sketchup 6 have no problems with this 😮
                      Dammit. If I knew that I could've filed a decent bug report on it - my problem is that at home I only have an English OS and keyboard so never noticed.
                      • AnssiA Offline
                        Anssi
                        It must be a Mac bug - I tried on my XP Home Finnish system, and I was able to export both to the desktop ("Työpöytä") and to a folder named "Hääyöaie"
                        Anssi
                        • O Offline
                          oski
                          Yes propably. MAC seems to have some problems with scandinavian characters (öäå...). I have also problems with mail attachments including non-english charracters.
                          20 nights to x-mas 🎉
                          • snicoloS Offline
                            snicolo
                            You Nailed it, this is a known issue on our part about non-English characters handling on the Mac.
                            We are working on it.
                            Simone.
                            Simone Nicolo
                            QA Manager
                            http://www.sketchup.com
