    Exporting shadows only?
    12 Posts 5 Posters 1.5k Views 5 Watching
    • J
      Japes
      Is there a better/more successful method of exporting only shadows then the method I currently use which is by making a new style and setting it to "Display Shaded Using All Same", with front and back faces set to default colour to white and edges turned off?
      The reason I ask is that I still get some edges/faces showing using this method.
      JP
      • R
        remus
        You might have a bit more luck if you smooth all the edges in your model first (select everything->right click->soften/smooth.)
        • Chris FullmerC
          Japes, I think that is the method I use, but I remember someone else posting another one that worked well too, but I don't recall what it was or what the benefits were. But both methods worked. I am wondering what faces or edges are still showing incorrectly? Do you have a model or at leat an image to show the problem? Thanks,
          Chris
          All my Plugins I've written
          • J
            Japes
            Thanks for the replies
            I've attached an image that might help, on reflection I think I'm wrong about the faces, I guess they are right in the example I've posted, but I'm still getting edges, although smoothing edges does help
            JP
            Shadows Example
            • T
              tomsdesk
              Do you have "profiles" turned off?
              2.5D Trees & Shrubs!
              • J
                Japes
                Hi Tom,
                Yes profiles are turned off.
                JP
                • T
                  tomsdesk
                  Figured so...can you post your model (from the posted pic): you've got my puzzle pot simmering :`)
                  • J
                    Japes
                    I deleted the last one 😳 but here is another and also an image of what I get!
                    Shadows.skp
                    • R
                      richcat
                      When exporting as jpg I get the edges shown ❓ , but as you can see I was able get rid of some of them by selecting an edge then context click and select entity and make hidden. πŸ’­
                      • Chris FullmerC
                        JP
                        The model you provided was set to hidden line mode which has a known bug for always displaying the lines on jpeg exports. I tried it by switching to "Display Shaded Using All Same" like you had said and it worked fine for me that way.
                        Try it again and see if that helps,
                        Chris
                        • J
                          Japes
                          Chris
                          Thanks Chris I checked the style I created and for some reason it was set to hidden line and not 'shaded all the same' as I thought. I've corrected that now and I'm getting better results, although I do see a slight hint of an edge, I also see that on your example, but I can live with that. Thanks for your help!
                          JP
                          • Chris FullmerC
                            Good, glad that helped. And yes, I also so that hint of a line. I wish it was not there too.
                            Chris
