    [Question] Ray cast a png
    14 Posts 6 Posters 1.3k Views 6 Watching
    • CadFatherC
      CadFather
      not sure this has been asked before - would the castray method work on a png?
      i know it doesn't work by casting shadows but i though if you could 'radar hit' a shape at the back of the image, you could perform a simple calculation of the profile, SU still seems to know about alpha channel...there could be a way to tell
      too early to be at work or possible?
      • R
        RickW
        Not sure I understand the question. What do you want to accomplish?
        RickW
        www.smustard.com
        • CadFatherC
          CadFather
          Hi Rick, after reading about Al Hart's tree generator i was thinking there could be a way to find out a rough profile of the transparent areas so the png can also be cut to simulate proper shadows (i mean without using external software)..
          of course this all proof of concept - i would not know where to begin with the code.
          • R
            RickW
            You mean similar to ImageProfile, just without the server-side processing?
            RickW
            www.smustard.com
            • GaieusG
              I guess that's what he means although I'm not sure wether by creating the geometry (which IP currently does).
              Actually, the ultimate solution would be if the GSU Development could achieve that shadow casting also recognises alpha transparency.
              • CadFatherC
                CadFather
                yes, it would be great if we could find a rough profile and draw it without leaving su
                Al's great plugin only needs this..
                i never used IP before - perhaps it could be made to be a localised process?
                Gaieus, to get alpha shadows you need GSU 23.5 😉 😄
                • GaieusG
                  Well, it is a commercial script and paid per/tree (or any other component). The plugin on your computer only communicates (or whatever) with the server.
                  I hope I can still se it - it would mean that I am the highlander as well though.
                  • CadFatherC
                    CadFather
                    if the processing power could be localised i'd buy the script - very often i do not have internet access - with Al's instant tree form creation, profiling is a quick must..
                    to be honest Gaeius, the way some of you are able to post on this forum i'd say you were highlanders!
                    off to work.. may google sketchup opitimus maximus shine on you all with graceful inference 😄
                    • Didier BurD
                      Didier Bur
                      Workaround: load your image in PhotoShop or Gimp, make a vector mask with the alpha channel and import it back into SU (you'll get a face). Then texture the face with the image.
                      Not a very process, but it works.
                      Just a though,
                      DB
                      • CadFatherC
                        CadFather
                        sorry Didier not sure i understand.. do you mean to load it from the rightclick 'edit texture image'?
                        • AnssiA
                          Anssi
                          @didier bur said:
                          Just a though,
                          I don't think either can save the vector path in a format that SU can import - a great idea though. Alan Fraser is using it, I think, but by saving the path as a DWG via Illustrator.
                          Anssi
                          • CadFatherC
                            CadFather
                            yes, that i know, ..for a minute i thought Didier meant we could do it without the ai-dwg process, which is still too un-sketchup..
                            • T
                              tomasz
                              No it doesn't work. You can try it with FrontFace script. I won't reverse a face behind alpha textured face, even if the texture is at the position of a cursor transparent.
                              New item on a Ruby API wish list?
                              Tomasz
                              • CadFatherC
                                CadFather
                                so although you can see through the transparent area of the image, you cannot access any info or get behind the scenes on how that is achieved..
                                last conceptual gasps before giving up then..
                                1. can ruby recognize image colour? (i think i can answer my own question in the negative)
                                2. could a ruby trace a line stroke (something like Didier's 'strokefield generator' if you know what i mean?)
                                3. lastly, (big chance) could a ruby script recognise/import an ai/svg file?
                                PS already tried the svg plugin but it's buggy (crashes and for some reason it messes up sandbox tools)
                                (promise i give up after this) 😉
