    A roof like this
    16 Posts 6 Posters 1.7k Views 6 Watching
      Mannie
      For my next challenge i want to make an old cottage, something like the one in this image http://www.foxearth.org.uk/FoxearthPictures/oldcottage2.jpg but how would i make a roof like that. with those 2 things in it. ?
      Are there any tuto's for that around ?
      Thanks in advance
      M.
        remus
        Heres how id do it, although theres almost certainly an easier way.
        cottage with sticky out bits.skp
          Mannie
          thanks, that looks easier than i thought it be 😉
            Mannie
            Well i made a start today 😉
            Does this look right ?
            Cottage
              Mannie
              To keep this project in the same topic is the best i guess. I'm having a bit of trouble with the window. when i put a transculent material on it it don't seem to work as it should. see image attached. any idea what the problem might be ?
              window
                remus
                It looks like z fighting, where 2 faces are in the same place and SU cant decide which one should be displayed. If you intersect the window with the model and then delete the face behind the window you should be able to get rid of it.
                • BepB Offline
                  Bep
                  Hallo Mannie,
                  The wall is showing threu the glass.
                  Make an opening in the wall as big as the window.
                  Bep van Malde
                  "History is written by the winners"
                    Mannie
                    I just figured it out, i had it grouped, seems ok now 😉
                    • rodrigonotorR Offline
                      rodrigonotor
                      Mannie, sorry for the off topic comment, which style you use for you model? looks very clean and nice.
                      • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
                        Mannie
                        I don't know what style i just started with this. I just start and see what it will be
                          rodrigonotor
                          Ok thanks, is the new arquitectural style from SU7
                            Hi Rodrigo,
                            Yes, it is an architectural template. I saved one for you (in SU 6); here it is attached. You can put it into your Templates folder and use it as your template.
                            I left Sang (who changed Bryce in SU 7 now) in it - you can purge him prior to saving it if you don't want him in the template. Also, the original template is in feet/inches OR millimetres; this one is in mm's as I suppose you use that.
                            ArchitecturalTemplate-mm.skp
                              rodrigonotor
                              Thanks Gaeius, downloading now.
                              I am actually thinking to upgrade to SU7 (no the pro), what do you think about it? I actually read the topic about of su7, but... not have clear, to much opinions.
                              But, thanks anyway for your time.
                              • Chris FullmerC Offline
                                I can't think of any reason to not upgrade. The new line breaking feature is different, but it is how I always wanted sketchup to work personally.
                                Also, the free version might be different, but with Pro you can keep su6 and su7 installed at the same time. There is no conflict there.
                                Chris
                                All my Plugins I've written
                                  rodrigonotor
                                  Thanks Chris, I give a try for the 8 hours version.
                                  Mannie, sorry again for the offtopic, what happend with your roof?
                                    Mannie
                                    still on the house 😉 . I'm just not that quick and continued in another topic about firewood and axe
