    DC - Grid Using Construction lines?
    9 Posts 3 Posters 1.0k Views 3 Watching
      I'm wondering if it's possible to create a dynamic grid using construction lines?
      Also, is there any way to create dynamic text? It'd be nice to be able to set a label for each grid line. X uses numbers and Y uses Letter.
      Example using normal SketchUp lines
        There is a grid rb on Didier's site: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
        First I thought you could add labels with the text tool to it to show the co-ordinates dynamically but as tested, that is not the case (and well, this is an expected behaviour of the tet tool really).
          But no way to do it with DC? I got some other things I'd like to use construction lines for as well. But I'd much rather use DC as I'm not familiar with ruby.
            Ok, I worked it out. I used the Xline ruby and converted the normal lines I had.
            Grid.skp
            Now then, onto making a radial grid. πŸ˜„
              But it'd still be good if text creation was possible...
                I also need some kind of a grid ruby (a kind currently is not available AFAIK) but with dynamic labeling and such.
                The only problem is that I should collect my ideas to clearly explain what I want. 😲
                  Hmmm... a couple of times when I did a Save As with this component the only thing that happened was that the original file was deleted. The new version wasn't saved. Anyone else experienced this?
                  Grid.skp
                  • scottliningerS Offline
                    scottlininger
                    Hey Thomthom,
                    DCs can't interact directly with text labels in SU, unfortunately.
                    Do you have a distinct series of steps that can create the "save as" problem?
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
                      It's not been consistent. I'll keep observing it and report back.
