    Two-point perspective tilt
    7 Posts 4 Posters 1.6k Views 4 Watching
    • S
      steve6
      Before I export to KT, I turn on the two-point perspective feature in SU to get rid of the three-point perspective tilt in default. But I just did a test render and the tilt is still there, even though it's in two-point!
      Any thoughts?
      • GaieusG
        The imple answer is: Kerkythea (or just SU2KT?) currently does not support either 2pt perspective or Parallel projection.
        It's just to "unnatural" for a PR renderer! πŸ˜„
        • S
          steve6
          Ah ha! How do I correct this in KT? or is it possible?
          • B
            bubbalove
            Kerkythea does do parallel projections... just go to View > Adjust > and click parallel but you will probably have to setup your camera again! I attached an example for ya...
            "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              Using a very long focal length or a very narrow angle of vision will be very close to parallel projection in SU. The smalest angle is 1Β° and the largest value for focal length is 2063 mm.
              Just ideas.
              • S
                steve6
                The model is in perspective!
                • GaieusG
                  Oops - I din't know that! 😳
                  Thanks David! πŸ‘
