    Pipe-along-path
    64 Posts 9 Posters 11.5k Views 9 Watching
    • C
      CRASHWORTHY1
      I promise I will try Tube-Along-Path as soon as I'm done evaluating version 9 of Pipe-Along-Path and get out of the hectic sketch I'm trying to complete these days. In fact, there are a lot of plugins I want to try that I've been missing out on for years. such as the dashed line generator.
      • TIGT
        PipeAlongPath will probably do you now as if you set the internal diameter to 0 it's remembered across sessions globally.
        Get the latest version of it from the PluginStore, but please wait a few minutes until I issue today's update 😉 ...
        • P
          pipingguy
          FYI - I don't think its the graphics card since it occurs in two different machines. And as far as the warning of impending doom - I trained myself to save before I initiate any sophisticated plugin command. All users should do it by instinct.
          Happy Piping!
            Sorry: what is "without BOM" ? 😳
            • mitcorbM
              mitcorb
              According to this: http://www.google.com/url?sa=t%26amp;rct=j%26amp;q=%26amp;esrc=s%26amp;source=web%26amp;cd=2%26amp;cad=rja%26amp;ved=0CC4QFjAB%26amp;url=http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FByte_order_mark%26amp;ei=RJMWU6AWk-jaBcqagPAO%26amp;usg=AFQjCNF3eTS_D5vLes7Ly5_7Q2t7dQisyg%26amp;bvm=bv.62286460,d.b2I
              Byte Order Mark.
              • P
                pipingguy
                @tig said:
                Notepad++ is a respectable product and if installed from their site it should not have other hidden baddies... http://notepad-plus-plus.org/download/v6.5.4.html
                I'll be reissuing PipeAlongPath shortly [edited entirely in Notepad++ !]
                I will be adding some optimistation tools...
                Good Day
                Are you still working on the PAP upgrade, or shall I stick with version 2.0?
                Thanks!
                • TIGT
                  v2.0 is the newest.
                  • P
                    pipingguy
                    OK! Super good work! (seriously)
                    • P
                      pipingguy
                      Attached, find model containing additional paths that will not extrude with PIPE-ALONG-PATH. 😞
                      PIPE-ALONG-PATH FAIL TO EXTRUDE COLLECTION.skp
                      • TIGT
                        The default diameter for the pipe is < 1/4" - which will mean some very tiny facets at bends etc.
                        Can you purge your SKP and include only the paths that still cause problems - I can't readily tell what's what - information overload !
                        Odd that FollowMe works on some and PipeAlongPath does not ?
                        • P
                          pipingguy
                          Not sure what you mean by purge. Just try any of the paths. You may want to avoid the ones labelled they will freeze the program. They should almost all be ''square''. I test that by creating temporary faces between vertices and placing the circle tool on the face. If the tool is red, green or blue, the linework is orthogonal and not skewed.
                          • TIGT
                            Model Info > Statistics > Purge Unused...
                            Removes the dross...
                            Makes the file much smaller and quicker to load/navigate...
                            There are so many examples, if you could offer a reduced set that includes only those paths which fail, then it'd be much easier to find what's up...
                            • P
                              pipingguy
                              Please see attached samples. FYI - my diameters are normally between 2'' and 18'' with 8 segments.
                              SAMPLES FROM PIPE-ALONG-PATH FAIL TO EXTRUDE COLLECTION 3-20-16.skp
                              • TIGT
                                All of those provided paths extruded a 4" diam pipe with PipeAlongPath, without any issues...
                                However, I did Select the entire path, then chose to Explode any Curves, and then used TIG-Weld to make a single bound path, which I then Selected and used with PiprAlongPath...
                                Can you try that ?
                                • P
                                  pipingguy
                                  I tried that, without luck. The weld extension I use looks like this:
                                  LOAD SUPPORT FILES
                                  require 'sketchup.rb'
                                  require 'extensions.rb'
                                  CREATE EXTENSION
                                  ext = SketchupExtension.new('Weld', 'smustard_Weld/weld.rb')
                                  EXTENSION INFORMATION
                                  ext.creator = 'Rick Wilson'
                                  ext.version = '3.0.1'
                                  ext.copyright = '2004, Rick Wilson'
                                  ext.description = 'Create custom toolbars through a WebDialog'
                                  REGISTER AND LOAD THE EXTENSION
                                  Sketchup.register_extension(ext, true)
                                  • TIGT
                                    I did NOT say to use RickW's old version. 😕
                                    I said 'TIG-Weld'...
                                    My simplified version is available here http://sketchucation.com/pluginstore?pln=TIG-weld
                                    Download/install it.
                                    Select the entire path.
                                    Use the Explode Curves in the context-menu [if any are found].
                                    Use TIG-Weld to make a bound-curve from the whole path.
                                    Select that... and use PipeAlongPath on it...
                                    • P
                                      pipingguy
                                      OK - so I deleted the old weld plugin and installed the TIG-weld ver-2.0 plugin. However, the plugin will not work. See attached.....
                                      TIG-weld ver 2.0 will not work.pdf
                                        How did you attempt to install TIG-Weld? Did you just put the downloaded RBZ file into Plugins?
                                        • TIGT
                                          Looks like you have not installed the RBZ, but rather just saved it into the ../Plugins folder...
                                          There seem to be a few RBZs in there !
                                          There is NO need for any RBZ to be in the ../Plugins folder - it does nothing any way.
                                          The normal 'manual' practice is to keep these RBZs in your 'Downloads folder, then install them...
                                          You install RBZ files.
                                          This has been the norm since v8M2.
                                          Use SketchUp's Preferences > Extensions > Install Extensions... button.
                                          Choose the RBZ and it then installs automatically, extracting the required files, subfolder of files and so on into your ../Plugins folder...
                                          If you had downloaded/installed the SkethUcation Toolset's RBZ [linked in menu above], then there is not even a need to download any RBZ - its ExtensionStore tool, when used from within SketchUp. automates the whole process behind the scenes ans downloads/extracts/installs the whole set of files for you, effortlessly...
                                          • P
                                            pipingguy
                                            Yes
                                            • 3 / 4
