    Easiest way to creat a sky for rendering?
    5 Posts 4 Posters 800 Views 4 Watching
    • Z
      zdphotos
      I'm slowly getting beyond the basics in SU, and I'm starting to play around with rendering in Podium.
      As such, I would like to add some clouds or some sort of sky seen through the window of a room. what is the best way to do this?
      I've thought about just creating a face outside of the window and applying a "sky" texture...would that work?
      thanks in advance!
      • Z
        zdphotos
        as a follow-up, I located a skydome but when I import it around my building, it basically eliminates the sun so I can't really see anything...everything is dark. is there a way around that?
        • AnssiA
          Anssi
          By far the easiest is to add a sky image as a watermark (to the style you are using, see Help)
          Anssi
          • S
            steve6
            A ractangle with a sky jpeg applied should work for you as well.
            • R
              remus
              If you still want to use a skybox, you could turn down the opacity of the texture to 65%, SU treats anything with less than 70% opacity as clear, so this should let the sun through without eliminating your skybox.
