    Move End of Line, without change Length
    7 Posts 5 Posters 834 Views 5 Watching
      cavemanatwork
      How can I move the End of a Line without changing the length of this Line?
        Jim
        Select the line and use the Rotate tool.
          cavemanatwork
          Thank you for your answer.
          But my Problem is this:
          I create 3 Lines, for Example 20, 30 an 40cm.
          How can I create a Triangle with this 3 Lines without changing their Length?
          Many Thanks for all Tips.
            Seems draw the line of 40, then draw 2 circles (radius 20 and 30) at the extremities give the solution πŸ˜‰
            Except the fact that circles are "polygons" and maybe precision will be not very accurate! πŸ˜’
              else a little trick πŸ’š
              View Top perspective disable
              draw a triangle base = 40 cm
              2 other sides with any size!
              Take the dimension tool and measure the 2 sides
              Select a side
              Take the Move tool and move the "top"
              When you see 30 cm & 20 cm you win! β˜€
              trick.skp
                Or use Didier's Trilateration plugin.
                • plot-parisP Offline
                  plot-paris
                  or group all the lines to make them seperate...
