    *.skp convert into *.wmv
    16 Posts 11 Posters 3.2k Views 11 Watching
    • E
      Emily
      I am running into a question that how to convert a schetchup file into WMV format, so client can watch the project with Powerpoint or Windows Media Player.
      thanks so much
      • J
        JuanV.Soler
        You can create scenes from your model and make an animation which can be saved as an avi. format. It can not be saved as WMW
        But it is good enough for windows media player or powerpoint.
        Cheers
        • brodieB
          brodie
          You could do your animation in SU but instead of exporting it as an .avi you can export it as a series of images and then use another program that will compile those images and turn them into an animation in wmv format.
          I use Adobe Premiere Elements 4.0 which can do this w/o too much of a learning curve. I think it cost $99 when I bought it about a year ago. There may be some free programs that do the same thing.
          -Brodie
          • DanielD
            Daniel
            If you are running Windows XP, you should have Windows Movie Maker (or you can download it from Microsoft for free). You can import a wide variety of image and video formats (including avi) and create a wmv file.
            My avatar is an anachronism.
            • plot-parisP
              plot-paris
              a free program is VirtualDub, which you can download here.
              simply import the images, change the framerate from 10 fps to something between 20 and 25.
              a good thing to do is to export the images from SketchUp with a higher resolution than the final movie (two or three times higher) and then use a "resize" filter in VirtualDub to scale it down to the desired resolution. like that all the lines will be a lot crisper in your animation and textured faces look better.
              • C
                chango70
                Thanks! I've been looking to find a program like this. Sweeeet. 😍
                • plot-parisP
                  plot-paris
                  yeah. what I really like about this program (apart from being free 😉 ), is it's simple functionality. for example if nothing is selected and you press the Delete button, the current frame will be deleted. if you select a passage, you can delete that as well...
                  and a lot of filter can be applied to get better results (like resize filter or a temporal smoother to make the animation less jerky).
                  • C
                    cosycat
                    I came across this the other day which might be useful, though I haven't had a a chance to try it out yet
                    http://www.archvision.com/discoveryviewer/
                    • GaieusG
                      Hi Cosycat,
                      Looks interesting, however it is limited to IE on Windows.
                      Hypercosm has a viewer with more browser support and it can run on Mac and Linux as well.
                      Also they have a free exporter and it can also be embedded into PP presentations.
                      • rodrigonotorR
                        rodrigonotor
                        I use this http://www.radgametools.com/bnkdown.htm very simple and free
                        • Sketchando.net • www.arqcad.net •
                        • W
                          wheay
                          Cheers
                          thanks for the help i want to know this. good thing i found it.
                          but how do i set the size of the screen?
                          "i try to learn everyday"
                          http://designerslandmark.blogspot.com/
                          • J
                            JuanV.Soler
                            When you export the animation you clik in OPTIONS ...
                            • W
                              wheay
                              wow! thank you very much!
                              • E
                                Emily
                                Thank you. but I found it ends up i have to give them my credit card number with expire date. Not sure if it's safe doing this.
                                • honoluludesktopH
                                  honoluludesktop
                                  After you create the SU animation with scenes, export it as a avi, then open it with Windows Movie Maker. It comes with WinXP, but I don't know about Vista (perhaps can be downloaded from MS). From there you can add titles, special effects, audio, and then export it as a wmv
                                  http://esr7kq.bay.livefilestore.com/y1pF3wM26Zz7ZiWOHGwOxqw1jbgRLbChcMtTU95OECoLiTosLFz65s3nFo60x9JCRHMMkKPRQk-yx1_aT2jV42QSQ/temp01.jpg
                                  file.
                                  • plot-parisP
                                    plot-paris
                                    sorry, somehow the links seems to have changed. just google 'Virtual Dub' and you will find a download link somewhere. it is definitely for free (so don't enter any credit card info! 😮 )
