    Components Intersecting - prevent this? Plugin available?
    18 Posts 7 Posters 2.6k Views 7 Watching
    • T
      tamfore
      Is there a script or plugin where you can prevent models from intersecting with another model it is near or touching... for example if you have a bowl of apples - and each apple is a separate component... you are dropping or placing each apple in the bowl in whatever arrangment you want... is there a script or plugin that can be used when placing the apples in the bowl that will make it easier to prevent intersecting with the other apples in the bowl???
      thank you
      Tamfore
      • axeonaliasA
        axeonalias
        Try Grouping the seperate objects when they are apart? Works for me
        https://sketchfab.com/Axeonalias
        • T
          tamfore
          Thanks...that is kind of what I have been doing... just wondering if there was a plugin similar to the drop plugin...
          thanks for your tip
          • T
            tamfore
            basically trying to see if there is a timesaving way to place them close to each other evening touching but not intersecting each other... other then just manually moving each apple to place it touching but trying not to intersect...
            thanks for everyone's assistance πŸŽ‰
            • boofredlayB
              boofredlay
              Tamfore, I think I know what you are talking about but unfortunately I have no solution. When I was working on this candy jar recently it was time consuming having to move each piece of candy and make sure they were not overlapping. It would be nice to have a script that limits the distance of movement when encountered with another object.
              http://www.formfonts.com/requestFile.php?type=1&id=11205&img=FF_Model_ID11205_1_FullTopOff.jpg
              • T
                tamfore
                That is exactly what I am trying to do - except with apples in a bowl... ok well i will just plug along manually - maybe soon they will come up with that plugin! thanks for your help.
                • boofredlayB
                  boofredlay
                  Sure, I just placed a request in the Ruby Forum Here. Maybe we will get lucky πŸ˜‰
                  • AnssiA
                    Anssi
                    I don't know for sure, but maybe this could be done with the SketchyPhysics or Drop plugins.
                    Anssi
                    • T
                      tamfore
                      have already tried the drop plugins... doesnt not give the correct effect completely
                      • C
                        Charlie__V
                        Sketchyphysics will work,after playing physics simulation....."cntrl A".......right click...group shape change....to static.
                        Charlie
                        • T
                          tamfore
                          thanks i will try it later tonight - i will post and let you all know how it goes
                          • GaieusG
                            How about Didier's component spray tool? There is something in it which prevents stacking afaik.
                            Tamore, let me, please, correct you a bit and clarify a misunderstanding here: "intersecting" means something different in SU therefore some folks above seemed to be giving dumb advices.
                            • T
                              tamfore
                              can you direct me where to find that spray tool?
                              • T
                                tamfore
                                can you send me a link or tell me how to find the "Didier's Component Spray tool
                                • bazB
                                  baz
                                  404 Not Found
                                  (www.sketchucation.com)
                                  • T
                                    tamfore
                                    THANK YOU
                                    • GaieusG
                                      Ah, sorry. I simply forgot the link.
                                      • T
                                        tamfore
                                        no problem - thanks for your help
