    Components Intersecting - prevent this? Plugin available?
    18 Posts 7 Posters 2.4k Views 7 Watching
      tamfore
      Thanks...that is kind of what I have been doing... just wondering if there was a plugin similar to the drop plugin...
      thanks for your tip
        tamfore
        basically trying to see if there is a timesaving way to place them close to each other evening touching but not intersecting each other... other then just manually moving each apple to place it touching but trying not to intersect...
        thanks for everyone's assistance πŸŽ‰
        • boofredlayB Offline
          boofredlay
          Tamfore, I think I know what you are talking about but unfortunately I have no solution. When I was working on this candy jar recently it was time consuming having to move each piece of candy and make sure they were not overlapping. It would be nice to have a script that limits the distance of movement when encountered with another object.
          http://www.formfonts.com/requestFile.php?type=1&id=11205&img=FF_Model_ID11205_1_FullTopOff.jpg
            tamfore
            That is exactly what I am trying to do - except with apples in a bowl... ok well i will just plug along manually - maybe soon they will come up with that plugin! thanks for your help.
              boofredlay
              Sure, I just placed a request in the Ruby Forum Here. Maybe we will get lucky πŸ˜‰
              • AnssiA Offline
                Anssi
                I don't know for sure, but maybe this could be done with the SketchyPhysics or Drop plugins.
                Anssi
                  tamfore
                  have already tried the drop plugins... doesnt not give the correct effect completely
                    Charlie__V
                    Sketchyphysics will work,after playing physics simulation....."cntrl A".......right click...group shape change....to static.
                    Charlie
                      tamfore
                      thanks i will try it later tonight - i will post and let you all know how it goes
                        How about Didier's component spray tool? There is something in it which prevents stacking afaik.
                        Tamore, let me, please, correct you a bit and clarify a misunderstanding here: "intersecting" means something different in SU therefore some folks above seemed to be giving dumb advices.
                          tamfore
                          can you direct me where to find that spray tool?
                            tamfore
                            can you send me a link or tell me how to find the "Didier's Component Spray tool
                            • bazB Offline
                              baz
                              301 Moved Permanently
                              (www.sketchucation.com)
                                tamfore
                                THANK YOU
                                  Ah, sorry. I simply forgot the link.
                                    tamfore
                                    no problem - thanks for your help
