    Ruby - PushPull to map size or proportion?
    5 Posts 4 Posters 787 Views 4 Watching
    • RichardR Offline
      Richard
      Just wondering if a script / function of the pushpull tool could be enabled or set limit the length of a push/pull action to that of the objects map size or a set proportion of it (= to the number of ie: brick repeats of the texture)?
      This would be handy to model in material units!
      Anyone? Just throwing the idea!
      BUILTBRAND.COM.AU
      • plot-parisP Offline
        plot-paris
        well, this idea could go hand in hand with the much requested control over inference modes.
        you open the inference dialog, and check/uncheck the options you want:
        • standard inference (endpoints, mitpoints, on-line, parralel...)
        • material inference (snapping to tiled textures)
        • predefined raster (you can change that already, but with the new dialog it is easier to access)
        I think, this is something to be implemented directly by Google rather than with a plugin...
          It should / could be built-in. You could make a tool that pushpulls to preset increments... See my RandomPushPull that has steps built in if desired...
          • RichardR Offline
            Richard
            Well I won't be holding my breath!
            BUILTBRAND.COM.AU
              Jim
              PushPull does use the Unit Snapping length, if it is set and so it will snap to the distance set there.
