    [Plugin] Remove group materials, leave geometry material
    88 Posts 27 Posters 71.1k Views 27 Watching
    • dereiD
      derei
      [FEATURE REQUEST]
      It's a useful plugin, until I found it, I had to remove all materials from selection using This Plugin, then reassign materials only to geometry inside group/component -often I have different materials on faces.
      I would like some features to this plugin: Now, with so many plugins, the Plugins Menu gets really crowded, so submenus are welcomed. So, I was thinking if you could add a feature to this plugin to remove all materials, something like this:
      REMOVE MATERIALS
      >Remove CG Materials
      >Remove ALL Materials
      In this way, instead of having two entries for those two plugins, I would have one single menu with two child options.
      Also, if the inputbox could be disabled, to speed-up the usage. I never replaced CG material using the inputbox, so for me is just a unnecessary mouse click πŸ˜„ Actually, I'm curious if anyone uses that feature.
      Thank you.
      DESIGNER AND ARTIST DEREI.UK
      • ToboboT
        Tobobo
        The link to the rapid share download doesn't work, can some post the script?
        Toby
        Philippians 4:13
        • GaieusG
          It's attached straight to the post here:
          http://forums.sketchucation.com/viewtopic.php?p=102323#p102323
          • ToboboT
            Tobobo
            Thanks Gai
            Toby
            Philippians 4:13
            • P
              Panga
              Thanks a lot for this plugin ! πŸ‘
              • M
                Myhand
                [FEATURE REQUEST]
                REMOVE MATERIALS
                >Remove CG Materials
                Thank you.
                This plugin should do what you want: http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                • srxS
                  srx
                  Thank you MyHand. Very useful plugin which I haven't seen it before. πŸ‘
                  www.saurus.rs
                  • B
                    blenditall
                    Just wanted to add my thanks -- this plugin works perfectly!
                    • 5 / 5
