    SketchUp RUBY API Wishlist [way of coding wishes, please]
    107 Posts 46 Posters 48.8k Views 46 Watching
    • K Offline
      kwalkerman
      Cool. Thanks again.
      • Dan RathbunD Offline
        Dan Rathbun
        @kwalkerman said:
        Cool. Thanks again.
        No problem.
        (bumping the topic..)
        • Made edits to the Layers code example* Added a second code example for Layer class.See previous post...
        I'm not here much anymore.
          Jim
          @kwalkerman said:
          In addition to retaining information on which layers are on and off, should also be able to retain the active layer for each page.
          I like this idea, particularly useful when adding text to Scenes. It seems quite possible using an Observer.
            Jim
            @dan rathbun said:
            @thomthom said:
            hm... never thought of that inconsistency before...
            model.materials.current vs model.active_layer
            "current and "active" should aliases for each other.
            Well, don't leave out Pages.selected_page!
              Dan Rathbun
              I don't know about that one... Pages are special. Even though you "select" a Page, depending on transition time, Sketchup can be animating somewhere between the previous page and the selected one.
              A FrameChangeObserver is needed to know when the animation is complete. Only at that point would I 'technically' say that a Page was the "active_page" or "current_page."
              @Karen. You can get an array of the hidden layers for a Page:
              mypage.layers
              so the visible layers would be:
              my_vis_layers = model.layers.to_a - mypage.layers
              • why they didn't name the method Page.hidden_layers, I don't know.
                Dan Rathbun
                @jim said:
                @kwalkerman said:
                ..., should also be able to retain the active layer for each page.
                But when you add text to Scenes (Pages,) are you drawing to the model, or drawing to the View ??
                If it's the View, then the active layer does not matter.
                The active layer is a property of the model. A Scene (Page,) is a View mechanism, which does not "have" layers; it only 'remembers' which of the model's layers to hide or show. A layer also has "new page behaviour" which it can tell new Scenes (Pages,) how to 'remember' their visibilty.
                I can see some problems for other scripts, if the active layer was automatically changed when a Scene changed. There would need to be some kind of toggle to turn the "auto" feature on and off.
                In addition, their would need to be scoping. What if an Observer was to be triggered while this "auto layer" feature was on? Outside the current script (or scope,) the Observer may want to "see" or "use" another layer as the active one.
                It also occurs to me, that we are supposed to always be drawing primitives on "Layer 0", but still some modelers want to draw on other layers (construction lines especially.)
                Anyway.. we'd need to consider this carefully. It could be a disaster.
                  Dan Rathbun
                  @kwalkerman said:
                  Seconded on the Layers usability, also, it would be great to be able to do:
                  Layers.active_layer
                  That can already be done:
                  Sketchup.active_model.active_layer
                  .. as it's a property of the model (Sketchup::Model class.)
                  see API: Model.active_layer
                  @kwalkerman said:
                  Layers[layer] = active
                  Will not work because there is no .= method defined for the Sketchup::Layer class. (You'd just be calling Ruby's internal hardcoded refererence assignment operator, which could set the layer reference on the left of the operator, to any kind of Ruby object. A bad idea, if it doesn't immediately cause an exception.)
                  This why the .new constructor is "hidden" (or made private,) and we create layers thru the collection class' .add method.
                  Sketchup.active_model.active_layer=layers['mylayername']
                  .. again, a property of the model (Sketchup::Model class.)
                  see API: Model.active_layer=
                  You CAN get a SKP DOM object's parent by using the .parent method. The model is the layer collection's parent, in the SKP doucment heirarchy. Where layers is the model's Sketchup::Layers class instance:
                  this_layer = layers.parent.active_layer
                  But, since each model instance, has an instance of a Sketchup::Layers class object, you'd think it (the Layers collection,) should also know which one of it's elements was active.
                  A simple Ruby patch for the Layers class:
                  class Sketchup;;Layers
                    unless method_defined?('active')
                      def active
                        self.parent.active_layer
                      end # def active
                    unless method_defined?('current')
                      alias_method('current','active')
                    unless method_defined?('active=')
                      def active=(arg)
                        if arg.class==String || arg.kind_of?Integer
                          self.parent.active_layer=self[arg]
                        elsif arg.class==Sketchup;;Layer
                          self.parent.active_layer=arg
                        else
                          raise(TypeError,'Sketchup;;Layer, String, or Integer expected.')
                      end # def active=
                    unless method_defined?('current=')
                      alias_method('current=','active=')
                  end # class extension
                  %(#4000BF)[**EDIT:
                  • added aliases* fixed method defintion tests**Note: The reason I do not call]Sketchup.active_model.active_layer (in the patch,) is to accomodate multi-model environment on the Mac, where the active model may not be the one a script is working on.
                  ADD: This can be extended to the Sketchup::Layerclass, so that a layer can return (boolean) whether it is the active layer or not.
                    unless method_defined?('active?')
                      def active?
                        # .equal? returns true ONLY if receiver and arg have same object_id
                        self.equal?( self.parent.parent.active_layer )
                      end # def active?
                    unless method_defined?('current?')
                      alias_method('current?','active?')
                    unless public_methods(false).include?('eql?')
                      # only override if it hasn't yet been redefined
                      def eql?(arg)
                          # we shall ignore the name attribute
                          # use the == override to include name in test
                          # use <=> to test only the names (match returns 0)
                          same = true
                          return (same = (self.page_behavior==arg.page_behavior)) if (not same)
                          return (same = (self.visible?==arg.visible?)) if (not same)
                          return same
                        else
                          raise(TypeError,'Sketchup;;Layer expected.')
                      end # override eql?
                  • TommyKT Offline
                    TommyK
                    I don't know if this thread is still checked by the Sketchup team, but I have one ruby request:
                    • be able to set selection colour per entity, including bounding box color.
                    It would allow different kinds of entities to be shown as such.
                      That's a very old feature request.
                      I think it was back at v7 I remember seeing members ask for groups and components to be different colours.
                      I love it to happen. Sorely needed in such a visual program.
                      • AdamBA Offline
                        AdamB
                        Pretty, but whats the use case?
                          slbaumgartner
                          @pout said:
                          does anyone know if any of the remarks here will be taken into consideration in a new version?
                          The SketchUp development team are famous for marching to their own inscrutable set of priorities, so only they know for sure. But this topic was started by a member of the team, so it is at least as good a place as any for sketchUcation members to post suggestions.
                            We're watching. πŸ˜‰
                            Since the Trimble acquisition a good number of have been addressed. That despite the fact that we've only had short dev cycles so far. Takes time to shift things around. But we're ramping up.
                            • tt_suT Offline
                              tt_su
                              I used the wrong - hat... So for the sake of making it right - with my Trimble hat: Yes we are watching. πŸ˜„
                              • TommyKT Offline
                                TommyK
                                If people wanted to distinguish some component types from others, for example. Or maybe a plugin could show a graphical overview of all the objects in a model to reflect some attribute, or something?
                                I have a plugin I want to create that uses 'external components'. To distinguish these from normal components for the user, having a different highlight colour would really help. More info on my thread: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59961
                                • tt_suT Offline
                                  tt_su
                                  You could do this with a custom Ruby Tool with the current API though. That is unless you want to display the graphical overview all time time.
                                  • TommyKT Offline
                                    TommyK
                                    Yes, with a custom Ruby Tool. I would like to be able to change the highlight colour when the standard selection tool is used, and I believe there is no way to do this. Would you suggest that I script an alternative selection tool to mimic the native tool and add the additional functionality?
                                    Perhaps the Sketchup team would find that the change to the API in this way would be too much of an intrusion to Sketchup's standard tools?
                                    • tt_suT Offline
                                      tt_su
                                      For the immediate solution with the current Ruby API that would be one way to do it. Though implementing the box selection is a challenge via Ruby - at least without performance impact of the tool.
                                      It would be a concern if there was multiple extensions that modified the selection colour of objects. Which extension would get the last say? And how easy would it be for the user to read the selection if the selection color changed?
                                      Having said that, we've had a couple of requests like this. If you would be able to mock up a real use case, a mock screenshot I can add that to a feature request in our bugtracker.
                                      I personally think it would be nice to have some generic way to draw additional graphic to the screen to display meta data etc. Not just changing selection colour.
                                        CAUL
                                        It would be nice if you could retrieve a face from Geom::PolygonMesh. For example:
                                        ` ent = Sketchup.active_model.entities
                                        ps = [[0, 0, 0], [0, 10, 0], [10, 10, 0]]
                                        mesh = Geom::PolygonMesh.new
                                        ps.each { |p| mesh.add_point p }
                                        ind = mesh.add_polygon ps
                                        ent.add_group.entities.fill_from_mesh mesh
                                        WISH
                                        f = mesh.get_face ind
                                        If you want to make a lot of manipulations on a complex piece of geometry, it is often an order of magnitude faster to recreate the manipulated geometry from scratch using fill_from_mesh rather than operating on the existing geometry using add/remove face. However, you often want to associate faces in the old geometry with corresponding faces in the new mesh geometry in order to copy over materials and so on, and this is where mesh.get_face would save a lot of time.
                                        • eneroth3E Offline
                                          eneroth3
                                          Isn't it already possible to just change the highlight color in the rendering options? It could be done from a selection observer and depend on what's currentply selected. Only supports one color at a time though.
                                          My website: http://julia-christina-eneroth.se/
                                          • tt_suT Offline
                                            tt_su
                                            +1 !
                                            • 6
                                            • 5 / 6
