    Need help with organic shapes
    4 Posts 3 Posters 956 Views 3 Watching
      ryaneiferd
      Salute SCF-ers!
      I'm so glad to have found this community, the forums have been of so much value. With that said...
      I need some help, either finding the right discussions or just a quick walkthrough of how to make organic shapes, or otherwise not normal shapes. I need to create things like:
      -big, pillowy boulders
      -tweaked wood beams
      -dented objects
      I work for a themed environment company and have been benefiting from using SU, but now I need to create more "toony" objects, ie stuff in Disney's Toon Town.
      Any help is greatly appreciated.
      Ryan
        mateo soletic
        Ryan, Wellcome to the community.
        The subdivide and smooth plugin is what you need.
        Have a look here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=9675&st=0&sk=t&sd=a&hilit=solo+toons
        Concept Illustrations
          ryaneiferd
          I'm on it Mateo. Thank you.
          Any good tutorials for using the tool? I saw the two videos on Smustard.com.
          • plot-parisP Offline
            plot-paris
            another great tool to deform and twist shapes is the FFD tool (Free Form Deformator)
            easy to use and with great results. only make sure, that your faces are subdivided enough before you use it.
            (I used it to make the shack in this image more skew)
