    SU export to Kerky -> no textures / bitmaps
    extensions
    12 Posts 5 Posters 2.9k Views 5 Watching
    • EddyNLE
      EddyNL
      Hey guys,
      I need your help!
      Formatted my computer yesterday. (Much faster now!)
      Installed SketchUP, Kerky and SU2KT3_0.
      (Installed SU2KT3_0 in the Sketchup main folder)
      When I'm trying to export a model to Kerky it gives me an error:
      "Tho following bitmaps are missing....
      and referring to the TX_ map.
      When I check the TX_ map there are no jpg files ???
      Did I make a mistake?
      Regards, Ward
      viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
      • EddyNLE
        EddyNL
        Edit:
        Even regular SketchUp materials don't export to Kerky, like bricks for example.
        HELP! πŸ˜’
        • S
          stanmarsh
          are you using the latest KT patch?
          • EddyNLE
            EddyNL
            Yep, cleaned my computer yesterday...
            Latest versions of SketchUp, Kerkythea and the SU2Kt exporter.
            • GaieusG
              Eduardo,
              By any chance,is there non-English characters
              • in your material names
              • in any of the folder names involved during the export
              • anywhere in the path you are exporting to/from or keep your materials?
              • EddyNLE
                EddyNL
                Here are some screenshots.
                Can you help me out?
                http://img361.imageshack.us/img361/3185/30195301ta9.jpg
                http://img380.imageshack.us/img380/7350/31926771xe2.jpg
                http://img412.imageshack.us/img412/6513/60417386zh0.jpg
                • R
                  rcossoli
                  you know you can be, maybe the textures are on the blue side of the model of SketchUp, that's why no charges, certain is that, I hope to help you, greetings
                  THREEDIMENSIONSWEB dot COM
                  • GaieusG
                    So under My Documents\Sketchup is there a folder named TX_1 and are the three image files in there?
                    Or that back face problem mabye (although AFAIK the latest exporter can do that, too).
                    • S
                      stanmarsh
                      hi Gaieus!
                      the problem was already resolved in the kerky forum, you can check it here
                      http://www.kerkythea.net/phpBB2/viewtopic.php?t=6379
                      • EddyNLE
                        EddyNL
                        Yes, you can close this one. Thanks.
                        Turned out to be a video card driver issue... I think.
                        I installed ASUS drivers for my ATI card instead of using shitty ATI Cataclyst drivers.
                        Problem solved πŸ˜•
                        • GaieusG
                          Cool, thanks guys for the heads-up. πŸ‘
                          • B
                            Bill Wilson
                            Problem solved πŸ˜•
                            Great to see you found a fix Ward, now can you please explain to an old man who is definitely not computer savy what is involved in installing a new driver as I have exactly the same problem as you had. I had no problem with SU textures but whenever I tried to use a .jpeg as a texture I got the same message in KT, it was very frustrating and I've been scratching my head for months about what the hell I was doing wrong. Until now I have seen nothing that explained it. Thank you for providing a bit of light on the subject. Now if you could just take me by the hand and lead me through the 'fix it process' I'll be a very happy chappy.
                            Cheers from the deep south where summer is just around the corner.
