    Dimensioning to the middle of a hole...
    7 Posts 6 Posters 1.6k Views 6 Watching
    • K
      kjacob
      Hi Folks,
      Newbie here.
      I couldn't figure out an elegant way to dimension to the middle of a hole in a plate and ended up having to "fake out" SU with two dummy lines, as shown.
      Can anyone show me a better way to do this?
      Thanks very much for any help.
      Ken
      • T
        tomsdesk
        If you hover a moment on the edge of a circle then move to the center it will usually snap to the center inference point....usually.
        2.5D Trees & Shrubs!
        • R
          ridix
          You can try to build the “Guide Point” first where hole center needs to be located. Than you can dimension it and construct the hole from it as well.
          • Jean LemireJ
            Jean Lemire
            Hi Ken, hi folks.
            See this SU file for ideas.
            Dimensionning without points to attach.skp
            • K
              kjacob
              Hello Jean,
              PERFECT!
              Thank you very much.
              (And to the others.)
              Ken
              • GaieusG
                Tom's method worked perfctly and for the first try, too! 👍
                • H
                  Hazza
                  Then there is the CentrePoint plugin from Smustard that will create a guide point for you.
                  Select the circle, Plugins -> Set center point, then dimension to the guide point.
                  See all of my SketchUp models here.
