ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Dimensioning to the middle of a hole...
7 Posts 6 Posters 1.2k Views
    kjacob
    Hi Folks,
    Newbie here.
    I couldn't figure out an elegant way to dimension to the middle of a hole in a plate and ended up having to "fake out" SU with two dummy lines, as shown.
    Can anyone show me a better way to do this?
    Thanks very much for any help.
    Ken
      tomsdesk
      If you hover a moment on the edge of a circle then move to the center it will usually snap to the center inference point....usually.
      2.5D Trees & Shrubs!
        ridix
        You can try to build the “Guide Point” first where hole center needs to be located. Than you can dimension it and construct the hole from it as well.
          Jean Lemire
          Hi Ken, hi folks.
          See this SU file for ideas.
          Dimensionning without points to attach.skp
            kjacob
            Hello Jean,
            PERFECT!
            Thank you very much.
            (And to the others.)
            Ken
              Tom's method worked perfctly and for the first try, too! 👍
              • H Offline
                Hazza
                Then there is the CentrePoint plugin from Smustard that will create a guide point for you.
                Select the circle, Plugins -> Set center point, then dimension to the guide point.
                See all of my SketchUp models here.
