    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] follow me rotate
    211 Posts 79 Posters 237.8k Views 79 Watching
    • F Offline
      frankfiv3
      no funciona, lo selecciono y no pasa nada
        marialuiz88
        hi im maria luiz and im new to sketchup πŸ˜„ may i know how to install this plugins to my su? thanks alot πŸ˜„
          Look at
          http://sketchucation.com/pluginstore?pln=Far
          Downloading this gives you an RBZ archive.
          Then use Preferences > Extensions > Install... button to install it for you...
          Read the tools usage guidance and other related posts...
          • pep75P Offline
            pep75
            Dear All,
            After installing this plugin in SU14, and after a restart, I got this error message. Am I missing something? 😳 Isn't this plugin compatible with the 2014 version? Thanks!!
              It does work with SU2014.
              Did you install it via the Extension Warehouse?
              • pep75P Offline
                pep75
                Thanks Dave. Uhm yep, via Extension Warehouse and later(after getting the Error)via the "install extensions" option in the preferences...mmm...still the same error.
                  Well, that's odd. It worked for me as you can see above but that was immediately after installing it via the Plugin Store. I closed SketchUp and reopened it and get the error you got. Now I would say it sort of works. The error is typical of plugins that need to be updated to be compliant with Ruby 2.0.
                  Alright! Where's wikii? He's got work to do.
                  By the way, the plugin still functions for me after clearing the error.
                    This is a weird issue. 😲
                    "FaR" comes in the RBZ archive with two rbs files, with 'cn' and 'en' suffixes.
                    These are versions of the same file, with only minor text differences.
                    If you have both files auto-loading, then the 'cn' one loads first and that would prevent the 'en' one from fully loading and making a menu entry, as it already claims its menu spot: however, both ought to 'load' [and do pre v2014].
                    The 'cn' one should use ChiNese wording for the Inputbox and the 'en' one ENglish...
                    BUT a typo in the author's code reverses that logic, and actually 'cn' is in English and 'en' is in Chinese.
                    So if you have both auto-loading then SketchUp loads the 'cn' version first [simple alphabetical order], that is successful in all SketchUp versions and you'll get English in the dialogs πŸ˜’ - BUT in v2014 the encoding of the Chinese characters in the 'en' version cause it to mis-load with that error-message.
                    When you freshly install from the FaR RBZ the 'cn' version auto-loads OK and makes the menu item.
                    The 'en' version fails 'silently'.
                    BUT when you restart SketchUp you then get the load error for the 'en' version, although the 'cn' version has already loaded OK - unless of course you have Disabled in the PluginsManager it or you have partially Uninstalled or removed that file...
                    So to stop that error message... πŸ€“
                    Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu].
                    From now on, when SketchUp loads, the 'cn' version [that's actually in English], it will be successful and there'll be no errors.
                    You sanity's sake you could also rename the 'cn' version as the 'en' version - or with no 'version' suffix at all...
                    The Chinese language version will not work with v2014 [but of course remember that arrives out of the RBZ named as the 'en' version !]
                    Another thing to bear in mind is that you need to preselect a single curve [path] and a single face [without its edges], and thirdly you can also include an optional guide-point, then use the tool from the Plugins menu...
                    Without the two minimum selections it will produce Ruby Console errors in all SUp versions...
                      Good catch, TIG. I see back a few years ago I made the comment about putting the CN version in and getting the plugin to work. I didn't realize the CN version is really in English and never tried removing the "EN" version. Hmmm....
                      • pep75P Offline
                        pep75
                        mmm...okay...I'll analyse TIG's "essay" thoroughly again, en then I'm going to test it...Thanks!!!
                          @pep
                          If you can't be bothered to read... πŸ˜’
                          Here's a prΓ©cis...
                          Delete the file FaR .rb, which has the 'en' suffix.
                          When SketchUp restarts the 'cn' version will load properly, giving you the ENglish version [perversely!]
                          The faulty 'en' version will not be there to load and so no more errors at startup. πŸ˜„
                          • pep75P Offline
                            pep75
                            Oh no TIG, then you misunderstood me...I was actually very glad with your analysis πŸ˜„..But I did what you wrote down and it still gave an error message(only deleting the cn version). I just removed the plugin, installed it again, removed the CN file...and again the error. Maybe my 'cocktail' of plugins doesn't match with this particular one! πŸ˜„
                            Well please don't spend to much time on this as I'm, I guess, the only one with this problem...Thanks Tig!
                              @pep
                              NO !
                              You do NOT remove the CN suffixed version πŸ˜’
                              Leave it where it is.
                              It is actually the ENglish version within the CN wrapper, owing to a code typo by the author.
                              So that CN version loads and works OK - giving ENglish menus rather than the ChiNese ones it was meant to make...
                              In v2014 the EN has some ChiNese text which causes failures...
                              So if you remove the EN version that error will stop appearing as SketchUp starts.
                              The CN one loads and works OK on its own...
                              BUT the EN one will always fail in v2014, so NOT having that EN one load just stops any related errors !
                              • pep75P Offline
                                pep75
                                Sorry, will try it! Thanks!
                                  myskp99
                                  Hello mates, hope one can answer this:
                                  installed the rbz file of follow me and rotate and it works, but at the begining of the program i get this message:
                                  Error: c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                                  c:/users/ivan/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                                  inp=Inputbox.new "Β±Γ€ΓΓŽΒΈΓΊΓ‹Γ¦"
                                  -e:1:in `eval'
                                  hope some help, why does this happen?
                                  thanks
                                    -e:1:in `eval'
                                    thanks
                                    See a few posts back http://sketchucation.com/forums/viewtopic.php?p=530627#p530627 and then http://sketchucation.com/forums/viewtopic.php?p=531322#p531322
                                    One of the .RBS files inside the RBZ is wrongly encoded [in Chinese!], so if you delete it the other version will load and work OK... Note the error in the file naming that is confusing - remove the EN but keep the CN version...
                                    • gonashviliG Offline
                                      gonashvili
                                      Seems super.
                                      Does it work for a free v8?
                                      Can't seem to install this.
                                        @gonashvili said:
                                        Seems super.
                                        Please [re]read the post immediately before your own...
                                        http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                                        You need to access this plugin's folder inside Plugins, and then delete an RBS file - illogically the EN version is wrong! - keep the CN one... πŸ˜’
                                          gonashvili
                                          Oh I had it working, just couldn't find it in the menu at first, then forgot to delete my post.
                                          Cheers πŸ˜„
                                            alnahrini
                                            Hi guys,,
                                            i just installed it, but i have this error message
                                            Note: am using sketchup 2016
                                            Error: c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
                                            c:/users/wasseem grou/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
                                            SketchUp:1:in `eval'
                                            please can any one help me..
                                            thanks in advance
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 8 / 11
