    [Plugin] follow me rotate
    211 Posts 79 Posters 253.2k Views 79 Watching
      sorgesu
      I thought this plug-in would be useful in finally solving the missing "sweep" tool, so I tried it. More specifically, I showed this one before, trying to make a squared handrail on a spiral staircase. Using follow me doesn't work because it curves the form so that the top isn't parallel with the ground. For this spiral stair case the steps are rotated 30 degrees so I tried the ruby with a 30 degree input. Totally didn't work. I tried various different inputs and I finally found one that visually, was "good enough". The input was -3 degrees.
      Can you take a look and let me know if there is a better number and if I there should be some relationship that can always be used to figure out what angle to use?
      Even if not, this saves just a ton of time as is and it is quite adequate for this job too! Thank so much.
      SpiralStairRail.skp
      Susan Sorger
      • W Offline
        wikii
        Another script still in development can do followme and keep the profile from rolling.
        Left part of the first image is followme ,right part is follow_me_and_keep .
        In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
          sorgesu
          Fantastic! Can't wait.
          Susan Sorger
            Sounds fantastic! That would be something needed so long!
            • E Offline
              Ecuadorian
              Follow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
              Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here:
              404 Not Found
              (www.crai.archi.fr)
              The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis.
              -Miguel Lescano
              • N Offline
                notareal
                A must have tool!
                • boofredlayB Offline
                  boofredlay
                  I am looking forward to it.
                  • E Offline
                    Ecuadorian
                    Until follow_me_and_keep is ready (which will save all these following steps), here's a workaround:
                    • Go to Camera > Standard Views > Left
                    • Draw your profile within the plane formed by the positive blue and green axis, touching the origin.
                    • Erase the face leaving the lines, and make it a component.
                    • Select your profile (it must be a curve or a polygon, if it isn't, first join the edges with the join tool by Rick Wilson in the SCF Power Toolbar).
                    • Use the "copy along distance" button on the SCF Power Toolbar (also a script by Rick Wilson) and play with the distance until you're satisfied.
                    • Select all instances of the component and explode them. You can use Rick Wilson's script "select all instances": http://www.smustard.com/script/Instances
                    • Click on the "configuration" button of the "Skin" script by Darrel to "By order". Leave the other options blank.
                    • Execute the "skin" command and keep pressing "Enter" like crazy until the full object is done.
                    • Add soften/smooth edges to your taste.
                    You can download the "skin" script from this post:
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin&start=105#p101209
                    And you can browse the rest of that thread for the latest version of skin.rb, too, if you want...
                    Yeah, it's a lot of extra work, that's why all await for follow_me_and_keep.
                    -Miguel Lescano
                    • david_hD Offline
                      david_h
                      This is pretty fun to play with.
                        ada123
                        it's really nice
                        • SwissmountainS Offline
                          Swissmountain
                          Thanks for this awesome script! 👍
                          Cogito ergo dum-di-dum
                            tamfore
                            is there a link for a text file or description and instructions on what this plugin does and how to use it?
                            thanks
                            Tamfore
                              thanks
                              Tamfore
                              Select welded edges as path and a face before using this script.
                              • K Offline
                                kostas_designer
                                Cool!...
                                Jeff: i think you are talking about the SCF POWERBAR:
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar#p112024
                                  ayieartwork
                                  guys.how to rotate the shape from bigger to smaller?
                                  Intel Core i7-3930k with 16gb G.Skill Ripjaws
                                  • brookefoxB Offline
                                    brookefox
                                    I unzip to plugins; get FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb, which I must rename as I have a larger file of that name already (I put far.skp elsewhere). No plugins result in my pull down. I rename them *.rb and still nothing. Any tips?
                                    ~ Brooke
                                      you must keep names *.rbs!
                                        brookefox
                                        OK, thanks, though they did not work that way ---> It dawned on me belatedly that I needed to provide for the re-naming or not of inbox.rb: if I rename it then I guess I need to go through the code and replace the old name with the new name wherever it occurs.
                                        ~ Brooke
                                        • Chris FullmerC Offline
                                          What? You already have a inputbox.rb? This plugin appears to have a file called that, as well as another plugin then? Do you know what other plugin supplied the other inputbox.rb? If you PM them both to me, I'll look at them and see if I can help un-entangle this issue. It will probably take more than just changing file names inside the script.
                                          Chris
                                          All my Plugins I've written
                                            brookefox
                                            Thanks, Chris.
                                            Yes; yes. The three being: FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb.
                                            Both inputbox.rb open as below, but are different implementations:
                                            Inputbox.rb Copyright 2008 jim.foltz@gmail.com
                                            The Inputbox class makes it easy to create user input
                                            dialogs by providing a consistent interface to UI.inputbox for
                                            text fields and drop-down selection fields.
                                            Checking the date stamps and my downloads leads to 2 DLs on 4.4.: inputbox and model_location.rb, which may or may not require input box (it has been snipped from some search result locations).
                                            Certainly I can try renaming the existing to something else in order to see if that will enable FAR.
                                            ~ Brooke
                                            • 6
                                            • 7
                                            • 10
                                            • 11
                                            • 5 / 11
