    [Plugin] follow me rotate
    211 Posts 79 Posters 243.7k Views 79 Watching
    • W Offline
      wikii
      @plot-paris said:
      and I have a suggestion for a future update:
      if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
      would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
      Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
      • plot-parisP Offline
        plot-paris
        weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
        but arround a curve it looks really cool! 😄
          marcosrodrigues
          Seems very promising, Wikii. Thank you.
          | menos é mais
            Your are not alone 😄
            And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
            yesno.skp
              Interesting plugin but this is what I get.
              http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
              http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
              http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
              http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
              • W Offline
                wikii
                select a face without it's border
                  thank you. that works.
                  • W Offline
                    watkins
                    Dear Pilou,
                    Thanks for posting the .zip file.
                    Regards,
                    Bob
                    • free agentF Offline
                      free agent
                      hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                      • jujuJ Offline
                        juju
                        We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                          cyan.archnet
                          simply "AMAZING", will give it a try, THANKS A LOT !!
                            dirkkkk
                            When I am using the plug in I get a bug splat... don`t know why 😞
                            Could It be because I am using a 64 bit system,
                            Thanks,
                              or it conflicts with another plugin.
                              You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                              • N Offline
                                notareal
                                Nice work!
                                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                • H Offline
                                  herodes
                                  I am having difficulties running this script. Inside the latest Far.rar I find:
                                  inputbox.rb -- for the interface
                                  FollowAndRotate_en.rbs -- the English version of the script
                                  FollowAndRotate_cn.rbs -- the Chinese version of the script
                                  far.skp -- example output
                                  I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                                  In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                                  load "FollowAndRotate_en.rbs"
                                  Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                                  RBS1.0
                                  C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                                  RBS1.0
                                  C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                                  (eval);87
                                  can you help me,...?
                                  %(#BFBFBF)[http://arhitektonas.blogspot.com
                                  I know me,... I am that guy...
                                  • W Offline
                                    wikii
                                    To load a rbs file,you can try to use Sketchup.load
                                      And for the little problem of orientation?
                                      • H Offline
                                        herodes
                                        Thanks for answering.
                                        I tried the suggesting and now I get :
                                        Sketchup.load "FollowAndRotate.rbs"
                                        false
                                        ... and there is still nothing in the "Plugins" menu.
                                        How did all the others get it working ?
                                        • H Offline
                                          herodes
                                          Sorry for bumping this thread.
                                          Please help.
                                            Daniel S
                                            Herodes:
                                            I think that you don´t install it well
                                            Put the three files in your plugin folder
                                            inputbox.rb
                                            Perhaps this fix your problem.
                                            Daniel S
                                            • 10
                                            • 11
                                            • 2 / 11
