    [Plugin] follow me rotate
    211 Posts 79 Posters 273.9k Views 79 Watching
    • W Offline
      wikii
      It is still in developing, here is the current version.
      [flash=600,338:1c4nqdq0]http://www.youtube.com/v/mVQ51i0G7AM[/flash:1c4nqdq0]
      Get the latest version as an RBZ from the PluginStore:
      http://sketchucation.com/pluginstore?pln=Far
      Select welded edges as path and a face before using this script.
        Daniel S
        Wikii
        I get a error on the ruby console
        I attach a image.
        Daniel S
        • W Offline
          wikii
          Try a curved path.
          • W Offline
            wikii
            @daniel s said:
            Wikii
            I attach a image.
            Daniel S
            • W Offline
              wikii
              A curve path
                Daniel S
                Wikii
                I attach a video showing what iΒ΄m doing...
                still I get a error in the ruby console.
                Daniel S
                error video.zip
                • soloS Offline
                  solo
                  I cannot seem to get it to work, I see it in the plugin drop down menu, but when I select it it does nada, does it work like follow me tool? if yes then I cannot seem to figure it out.
                  http://www.solos-art.com
                  • W Offline
                    wikii
                    • W Offline
                      wikii
                      Sorry , I modified two classes.
                      Please download again
                        Daniel S
                        Now works..
                        thank you Wikii!!
                        πŸ‘
                        Solo...
                        install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face.
                        Daniel S
                        • soloS Offline
                          solo
                          I have tried that without anything happening.
                          • W Offline
                            wikii
                            @daniel s said:
                            Now works..
                            thank you Wikii!!
                            πŸ‘
                            Solo...
                            Daniel S
                              Daniel S
                              Solo...
                              try with the ruby console open like in the video i attach here:
                              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900
                              And if it gives error send the error to wikii.
                              For me is working now.
                              Daniel S
                              • soloS Offline
                                solo
                                hey, It works!
                                http://img407.imageshack.us/img407/2218/imageoftwist1qo2.jpg
                                Thanks mate.
                                • EarthMoverE Offline
                                  EarthMover
                                  It's working for me also. Thanks sooo much wikii!!
                                  Content Creator at Skapeup
                                    silver_shadow
                                    %(#FFBF00)[Wheeee, thanx a million !!! β˜€]
                                    • bigstickB Offline
                                      bigstick
                                      This is fantastic! Thanks a lot wikii!
                                      • plot-parisP Offline
                                        plot-paris
                                        phantastic plugin Wikii! thanks for sharing 😍
                                        however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
                                        http://img205.imageshack.us/img205/3448/far01kh7.jpg
                                        and I have a suggestion for a future update:
                                        if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
                                        would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
                                        or even better, could you change the script to allow the use of several seperate faces?
                                        http://img87.imageshack.us/img87/8549/far02vh5.jpg
                                        • W Offline
                                          watkins
                                          Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
                                            Funny πŸ‘ β˜€ 😎
                                            Done πŸ˜‰
                                            Far.zip
                                            • 10
                                            • 11
                                            • 1 / 11
