    Square Tube Along Path plugin?
    7 Posts 6 Posters 4.4k Views 6 Watching
      midlana42
      Is there a "Square Tube Along Path" like the "Pipe Along Path" plugin? I'm also willing to accept a plug in that does Polygon Along Path if I can spec the number of faces. Thanks!
        remus
        Cant you set the number of faces in pipe along path? set the number of faces to 4...
        • EarthMoverE Offline
          EarthMover
          Or, you can use the newest line2cylinders ruby and change the precision to 4. This will give you a square along a path.
          Content Creator at Skapeup
          • P Offline
            pmiller
            Or use TIG's tubealongpath ruby:
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_geo_page.htm
              midlana42
              Doh!
              You're right, that works fine, though it's too bad it doesn't make the top surface parallel to the red/green plane, but beggers can't be choosers; I can rotate it. Thanks!!
              [edit] Well that's annoying. The way it draws a square, I have to put in the diagonal distance in order for the flat-side dimension come out right. That is, putting in a radius of 0.707 gives a 2" square tube. Oh well, it's still better than having to do it manually.
                Brigadoon
                β˜€ Where can i find this line2cylinders ruby? β˜€
                  TIG's
                  ExtrudeAlongPath.rb - select the path then specify rectangle's details...
                  or
                  ExtrudeEdgesByFace.rb where you draw a flat rectangular [or any shaped] face with up as its Y/green axis and have a path of welded edges...
