    How to pause a ruby script for 1 second
    25 Posts 5 Posters 6.6k Views 5 Watching
    • N
      N Lindenthal
      @alexmozg said:
      …And completely to get rid from selection.
      Where I can find "following.rbs"?
      I shall think...
      Yes, rid from selection …
      … but how? This way?
      select_comp_by_name("Fahrstuhl")
      def Morisdov.transf_get(dict_key, ss=nil)
        model=Sketchup.active_model
        ents=model.active_entities
         if ss
           @ents = ss
         else
           @ents=[]
           model.selection.each {|e| @ents.push(e)}
        @ents.freeze
        model.selection.clear
      (my poor english) Which "following.rbs" you need?
      • A
        AlexMozg
        def select_comp_by_name(comp_name)
           model = Sketchup.active_model
           if compdef = Sketchup.active_model.definitions[comp_name]
              sel = compdef.instances
           else
              sel=[]
              Sketchup.active_model.active_entities.each do |d|
                 if d.typename == "ComponentInstance"
                 sel << d if d.name==comp_name
              if sel.count == 0
                 UI.beep
              else
                 UI.messagebox(sel.count.to_s + " gesuchte Dinger gefunden.")
        sel
           if ss
             @ents = ss
           else
             @ents=[]
          @ents.freeze
          ...<<original code>>...
        Use:
        1. ss = select_comp_by_name("Fahrstuhl")
        2. Morisdov.transf_get(dict_key, ss)
        Here this:
        ...Position 2
        To get the script work, the following .rbs must be installed:
        • Chris FullmerC
          I know this is old, but I was needing an answer to something similar today, and this thread over-complexificated the issue for me. I just wanted to add a short .2 second delay before carrying on with my script. This is what I've come up with and it worked for me. No need to invoke the UI.timer
          time_mark = ( Time.now + 0.2 )
          while time_mark > Time.now
          Hopefully thats helpful if anyone stumbles on this thread,
          Chris
          All my Plugins I've written
          • tbdT
            tbd
            Chris: i hope your code is called only by the user and not in an Observer or right click menus, because it will stop Ruby thread and if you call this several times it will block a lot of things.
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
            • Chris FullmerC
              Ahh, I see. I think its ok in this instance to stop up ruby entirely. I was having very little luck getting it to work any other way. I just kept sending SU into a deeep coma.
              Maybe I'll try to post my broken code using the timer and try to get that working instead then. Thanks Tavi,
              Chris
              • 2 / 2
