    [Plugin] Toggle Units
    159 Posts 47 Posters 139.4k Views 47 Watching
      Matt666
      Hi all.
      Sorry for my absence, for now I don't often use SU. Thank you TIG to be here... 😳
      Frenglish at its best !
      My scripts
        mag1800
        [floatr:2nr8pix2][/floatr:2nr8pix2]Great Plugin Matt. Works great for me. Thank You.
          Matt666
          Hi all.
          Plugin updated with a new tool (Toolbar manager): You can now choose icons you want to display in the toolbar.
          Thanks to Thomthom and TIG!
          LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
          My scripts
            Matt666
            Do not hesitate to tell me if something goes wrong... I'm new with HTML and JAVASCRIPT...
            My scripts
              driven
              Hi Mat,
              on my mac if I instal this correctly and open SU
              Unless, I use the manager, make a change and then quit
              SU actually crashes when I close a window and I get a report dialog.
              When I remove this ruby, everything works as it should, if put it back again problem returns.
              it make no difference if I use or don't use the plugin, only if it's installed.
              %(#BF0040)[28 com.google.sketchupfree8 0x004a9316 std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 1968
              29 com.google.sketchupfree8 0x004aa4ab std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem >::_M_insert_aux(__gnu_cxx::__normal_iterator<CSketchUpToolbar::CToolBarItem*, std::vector<CSketchUpToolbar::CToolBarItem, std::allocatorCSketchUpToolbar::CToolBarItem > >, CSketchUpToolbar::CToolBarItem const&) + 6469
              30 libCommonUtils.dylib 0x00a8538a CNotificationCenter::SendNotification(char const*, void*) + 202
              31 com.google.sketchupfree8 0x004c1d48 non-virtual thunk to CTool::~CTool() + 3048
              32 com.google.sketchupfree8 0x004c27c3 non-virtual thunk to CTool::~CTool() + 5731
              33 com.google.sketchupfree8 0x00008335 0x1000 + 29493]
              john
                Matt666
                Hum Thomthom told me I had to use 'show' with windows and 'show_modal' with mac... I think this is the problem (because i completely forgot this!). I'll take a look soon thank you!
                My scripts
                  driven
                  Hi Mat,
                  It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
                  .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
                  john
                    Matt666
                    Hi!
                    See first post to download new version [v2.11].
                    • Mac bug fixed
                    • Add tool in extensions window.
                      Big thanks to driven for his help! πŸ‘
                    My scripts
                      ankitdarda
                      thanks a lot..
                      http://forums.sketchucation.com/posting.php?mode=reply&f=323&t=11745#
                      thank you !!!
                      feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                      :sunglasses:
                      ankitdarda
                        Matt666
                        πŸ˜‰
                        My scripts
                        • U Offline
                          ultimato andy
                          where is the pluggin to download for sketchup 8? i cant find it!:(
                            Attached to the first post of the topic (usually at the bottom)
                              Matt666
                              Thank you Gaieus!
                              My scripts
                                mirale999
                                Great plugin~ I find it easy to switch from mm to M when just to measure the area of a plan now!
                                paranoia is a higher form of awareness...
                                  driven
                                  Hi.
                                  I don't think it's a Lion issue... per say
                                  on the mac the MF_UNCHECKED MF_CHECKED just doesn't work to your advantage, and after a few wrong combinations, it stops switching the screen text, although console says it's working.
                                  if you run it with RC open you can see that your better off re-clicking the currently selected first, to turn the shadow off, then changing. it's a drag, but SU enabled the native buttons behavior to latch and when it also coded to latch....
                                  the mac native SU button code needs to be modified, then we can have buttons the toggles, like 'some' native SU ones that were set up correctly.
                                  as a stop gap I changed the MF_CHECKED to MF_UNCHECKED, which sightly reduces confusion.
                                  john
                                  • mariochaM Offline
                                    mariocha
                                    Well, no luck here on OS X Lion, with v 2.11
                                    Only the first 4 icons and the 2 setting the precision work; And the greyed out icons stays on when it should go out.
                                    %(#008000)[Mario C.
                                      driven
                                      no the native setting will still shadow the buttons as if selected, the light greying seems to work, until it/you gets confused,
                                      it only works on unavailable options, so maybe the fractions/decimal triggering could be modified to make it more intuitive...
                                      I just turned off Fractions and Arch and Use ENG in either metric or imperial, but with decimals only.
                                      I understand fractions, but not the use of them.... although they should run faster with binary conversions....
                                      john
                                      • mariochaM Offline
                                        mariocha
                                        Oh ! you mean the shadowing of the buttons is within SU. πŸ˜•
                                        Oh well, then I can just re-click it to make the shadow go.
                                        Here in Quebec, we are caught between 2 worlds so I have to use both Arch. and Met.
                                        %(#008000)[Mario C.
                                        • mariochaM Offline
                                          mariocha
                                          Hum... in this case, we do not really need the current icon being greyed cause we can see witch is the current unit setting just by looking at the dimensions in the model.
                                          The main drag is that some do not work. Maybe taking the "greying" part of the code out ? ❓
                                          update; I deleted the "MF checked-MF unchecked" and "validation" parts and they now all work fine.
                                          Now If I could find how to disable the greying out of the icons. πŸ˜„
                                          %(#008000)[Mario C.
                                            driven
                                            hay,
                                            I'm in England, 50% of the population think mm is the Mickey Mouse Club and the rest think a foot is on the end of their leg...
                                            I work with both
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
