    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
      ankitdarda
      thanks a lot..
      404 Not Found
      (forums.sketchucation.com)
      thank you !!!
      feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
      :sunglasses:
      ankitdarda
        Matt666
        πŸ˜‰
        Frenglish at its best !
        My scripts
        • U Offline
          ultimato andy
          where is the pluggin to download for sketchup 8? i cant find it!:(
            Attached to the first post of the topic (usually at the bottom)
              Matt666
              Thank you Gaieus!
              My scripts
                mirale999
                Great plugin~ I find it easy to switch from mm to M when just to measure the area of a plan now!
                paranoia is a higher form of awareness...
                  driven
                  Hi.
                  I don't think it's a Lion issue... per say
                  on the mac the MF_UNCHECKED MF_CHECKED just doesn't work to your advantage, and after a few wrong combinations, it stops switching the screen text, although console says it's working.
                  if you run it with RC open you can see that your better off re-clicking the currently selected first, to turn the shadow off, then changing. it's a drag, but SU enabled the native buttons behavior to latch and when it also coded to latch....
                  the mac native SU button code needs to be modified, then we can have buttons the toggles, like 'some' native SU ones that were set up correctly.
                  as a stop gap I changed the MF_CHECKED to MF_UNCHECKED, which sightly reduces confusion.
                  • mariochaM Offline
                    mariocha
                    Well, no luck here on OS X Lion, with v 2.11
                    Only the first 4 icons and the 2 setting the precision work; And the greyed out icons stays on when it should go out.
                    %(#008000)[Mario C.
                      driven
                      no the native setting will still shadow the buttons as if selected, the light greying seems to work, until it/you gets confused,
                      it only works on unavailable options, so maybe the fractions/decimal triggering could be modified to make it more intuitive...
                      I just turned off Fractions and Arch and Use ENG in either metric or imperial, but with decimals only.
                      I understand fractions, but not the use of them.... although they should run faster with binary conversions....
                      • mariochaM Offline
                        mariocha
                        Oh ! you mean the shadowing of the buttons is within SU. πŸ˜•
                        Oh well, then I can just re-click it to make the shadow go.
                        Here in Quebec, we are caught between 2 worlds so I have to use both Arch. and Met.
                        %(#008000)[Mario C.
                        • mariochaM Offline
                          mariocha
                          Hum... in this case, we do not really need the current icon being greyed cause we can see witch is the current unit setting just by looking at the dimensions in the model.
                          The main drag is that some do not work. Maybe taking the "greying" part of the code out ? ❓
                          update; I deleted the "MF checked-MF unchecked" and "validation" parts and they now all work fine.
                          Now If I could find how to disable the greying out of the icons. πŸ˜„
                          %(#008000)[Mario C.
                            driven
                            hay,
                            I'm in England, 50% of the population think mm is the Mickey Mouse Club and the rest think a foot is on the end of their leg...
                            I work with both
                              Matt666
                              Hi. I apologize for mac bugs, I have no mac to test plugins... 😠
                              Did you see there is an option that lets you choose icons you want to display? You can hide fractional icon if you want.
                              My scripts
                              • E Offline
                                element
                                Useful plugin.
                                  pololo
                                  Useful plugin!!! Thanks!!
                                    Pete
                                    Matt666, thank you for the very handy plugin. I use this all the time and was wondering if I could make one request...
                                    Could you add a favorites toggle? What I mean by this is allow the user to set favorite units / precision combinations they could toggle between with one click. In my case I need to toggle CM with 0.0 precision and Inches with 1/16 precision constantly. If I could set these two as favorites and have one button that would switch between only those two I would owe you!!
                                      Matt666
                                      Hi Pete! Thank you for your kind words..
                                      i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! πŸ˜„
                                      But I love programming so I will try to do something for you..
                                      I just have to reinstall SU!
                                      My scripts
                                        design54
                                        i have a question please;
                                        can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
                                        thank you
                                        waiting your feedback
                                          thank you
                                          Obviously you can't 'sell' someone else's creation, but the use of most of the forum's 'free' tools in your 'business' is acceptable, unless there is something specifically in a tool's 'notices' saying you can't... In this case it's 'All Rights Reserved... Free License...' etc but with no other limitations that I can see...
                                          Having said that it would be nice to offer an author a modest PayPal donation - after all if you are making money from a tool then sharing some of it would only seem fair... "What goes around comes around..."
                                          Matt666 doesn't have a donation button on the 'SketchUcation Plugin Store', but this doesn't prevent you sending him a Private Message and asking the question... If he declines you are no worse off, if he accepts you might feel better in your heart...
                                          • atelierpaarA Offline
                                            atelierpaar
                                            Hello there,
                                            I just installed SU 2014,
                                            After downloading Matts Toggle_Units.rb using the sketchucation download-Manager I get the following Error message:
                                            Fehler beim Laden der Datei Matt_Toggle_Units.rb
                                            Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                                            Sketchup.register_extension (ext,true)
                                            Any Idea how to fix this ?
                                            thank`s for your comments,
                                            Uli
                                            • 6 / 8
