    [Plugin] Toggle Units
    159 Posts 47 Posters 144.8k Views 47 Watching
      driven
      Hi Mat,
      It actually seems to be something to do with the preference settings, which SU sends to the .plist on Mac.
      .show and .show_modal never cause crashes, it's just the dialog disappears under the main window.
        Matt666
        Hi!
        See first post to download new version [v2.11].
        • Mac bug fixed
        • Add tool in extensions window.
          Big thanks to driven for his help! πŸ‘
        LINK: http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
        Frenglish at its best !
        My scripts
          ankitdarda
          thanks a lot..
          http://forums.sketchucation.com/posting.php?mode=reply&f=323&t=11745#
          thank you !!!
          feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
          :sunglasses:
          ankitdarda
            Matt666
            πŸ˜‰
            My scripts
            • U Offline
              ultimato andy
              where is the pluggin to download for sketchup 8? i cant find it!:(
                Attached to the first post of the topic (usually at the bottom)
                  Matt666
                  Thank you Gaieus!
                  My scripts
                    mirale999
                    Great plugin~ I find it easy to switch from mm to M when just to measure the area of a plan now!
                    paranoia is a higher form of awareness...
                      driven
                      Hi.
                      I don't think it's a Lion issue... per say
                      on the mac the MF_UNCHECKED MF_CHECKED just doesn't work to your advantage, and after a few wrong combinations, it stops switching the screen text, although console says it's working.
                      if you run it with RC open you can see that your better off re-clicking the currently selected first, to turn the shadow off, then changing. it's a drag, but SU enabled the native buttons behavior to latch and when it also coded to latch....
                      the mac native SU button code needs to be modified, then we can have buttons the toggles, like 'some' native SU ones that were set up correctly.
                      as a stop gap I changed the MF_CHECKED to MF_UNCHECKED, which sightly reduces confusion.
                      • mariochaM Offline
                        mariocha
                        Well, no luck here on OS X Lion, with v 2.11
                        Only the first 4 icons and the 2 setting the precision work; And the greyed out icons stays on when it should go out.
                        %(#008000)[Mario C.
                          driven
                          no the native setting will still shadow the buttons as if selected, the light greying seems to work, until it/you gets confused,
                          it only works on unavailable options, so maybe the fractions/decimal triggering could be modified to make it more intuitive...
                          I just turned off Fractions and Arch and Use ENG in either metric or imperial, but with decimals only.
                          I understand fractions, but not the use of them.... although they should run faster with binary conversions....
                          • mariochaM Offline
                            mariocha
                            Oh ! you mean the shadowing of the buttons is within SU. πŸ˜•
                            Oh well, then I can just re-click it to make the shadow go.
                            Here in Quebec, we are caught between 2 worlds so I have to use both Arch. and Met.
                            %(#008000)[Mario C.
                            • mariochaM Offline
                              mariocha
                              Hum... in this case, we do not really need the current icon being greyed cause we can see witch is the current unit setting just by looking at the dimensions in the model.
                              The main drag is that some do not work. Maybe taking the "greying" part of the code out ? ❓
                              update; I deleted the "MF checked-MF unchecked" and "validation" parts and they now all work fine.
                              Now If I could find how to disable the greying out of the icons. πŸ˜„
                              %(#008000)[Mario C.
                                driven
                                hay,
                                I'm in England, 50% of the population think mm is the Mickey Mouse Club and the rest think a foot is on the end of their leg...
                                I work with both
                                  Matt666
                                  Hi. I apologize for mac bugs, I have no mac to test plugins... 😠
                                  Did you see there is an option that lets you choose icons you want to display? You can hide fractional icon if you want.
                                  My scripts
                                  • E Offline
                                    element
                                    Useful plugin.
                                      pololo
                                      Useful plugin!!! Thanks!!
                                        Pete
                                        Matt666, thank you for the very handy plugin. I use this all the time and was wondering if I could make one request...
                                        Could you add a favorites toggle? What I mean by this is allow the user to set favorite units / precision combinations they could toggle between with one click. In my case I need to toggle CM with 0.0 precision and Inches with 1/16 precision constantly. If I could set these two as favorites and have one button that would switch between only those two I would owe you!!
                                          Matt666
                                          Hi Pete! Thank you for your kind words..
                                          i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! πŸ˜„
                                          But I love programming so I will try to do something for you..
                                          I just have to reinstall SU!
                                          My scripts
                                            design54
                                            i have a question please;
                                            can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
                                            thank you
                                            waiting your feedback
                                            • 6 / 8
